Hi all,
I've been slowly restoring what I believe to be a 1907 Sebastian lathe, based on this post I found:
Photo Index - Sebastian Lathe Co. - Engine Lathe | VintageMachinery.org
I've attached an image of my one as well for reference. It is missing some parts, I presume due to prior disassemblies for transporting and/or rebuilding. Hence I'm after bits listed below. If there's anything I could otherwise adapt or build to make up for these bits, or perhaps parts from other lathes, I'm open to ideas.
Missing parts:
- tailstock
- change gears
- lead screw + mounting hardware
- lead screw apron gearing
- power feed + mounting hardware
- back gear cover
Missing parts:
- tailstock
- change gears
- back gear cover
