First, yes the lathe is level. Let's get that out of the way.
I decided to align my tailstock to dead nuts. I started by indicating from the chuck to a dead center in the tailstock that's when I saw the following: I aligned the tailstock to .000 on left and right and then as soon as I loosened the tailstock the indicator sprang .005. Ok that's to be expected, but when I tightened it back down it stayed out .005. I recentered it to .000 and loosened the tailstock and retightened, boom, exact same thing.
I have taken apart the tailstock and cleaned everything and all the lathe bed ways and it is still happening. This tailstock design doesn't have the 2 screws setup it has 1 lead screw through a threaded boss on the base.
left at 0:
right at 0:
The spring back after loosening and retightening.
Tailstock adjust screw:
Any thoughts? Also I have learned tailstock is low by .003, how much does that affect concentricity?
Cheers,
OldTom
left at 0:
right at 0:
Cheers,
OldTom
