Sheldon No. 0 Horizontal Mill
Results 1 to 11 of 11
    Apr 2017
    5
    Default Sheldon No. 0 Horizontal Mill
    Hello.
    I bought this machine a few months and am just now getting it setup in my garage. I noticed there was play in the spindle, so I tried taking it apart to inspect the bearings. I know from the manual that the spindle comes out of the front, but the rear inner bearing race is stuck to the spindle. What is the best way to remove it?
    I'll try to get some pictures up later.
    Scott
    Attached Thumbnails Attached Thumbnails img_20170414_135233900.jpg   img_20170414_135226705.jpg   img_20170414_135242419.jpg   img_20170414_135246891.jpg
    Mar 2005
    Maine
    1,301
    9
    512
    Here's some parts lists with drawings that may help.
    Sheldon Machine Co, Inc. - Publication Reprints | VintageMachinery.org
    Oct 2012
    Virginia
    10,264
    5843
    4628
    Quote Originally Posted by spfrazierjr View Post
    If you can get a needle, whether hypodermic or basketball inflator, in to flush the bearings with Kerosene, then renew the lube, the best answer could be 'not at all'.
    If after cleanup and re-lube, they MEASURE too much TIR to want to keep and run, then:
    - thoroughly stone and otherwise de-bur the area the race will have to be pulled across. Depressions with no burrs will be harmless. Anything at all raised will try to 'cock' the race and it can jam. HARD!
    - Kroil / PBlaster the piss out of it, give it days to act, periodic renewals. Heat-gun or hair-dryer AND NOT torch AKA 'gas hammer'.
    - NO hammering. Can Brinell an otherwise good bearing.
    - NO pushing from the rear. Swells the spindle ever so slightly.
    - Instead pull from the front. Automotive spiders, some bolts or allthread, hydraulics if yah got 'em. You'll have to get creative.
    If you can clean, re-lube, and test for for acceptable TIR on the front as well as rear, don't pull either set. Run what yah got.
    Overarm needs serious de-burr and GENTLE rust removal. Pay attention to the ends. They are usually upset mushroom-style at least a little bit by Bubba's careless hammering.
    Again, significant depression matter not, anything at all raised is problematic. As is rust.
    Clean first. Remove second. Or even not at all.
    Apr 2017
    5
    Thanks for the information guys.
    A bit more info for you. The play I am referring to is front to back if you're standing at the front of the machine. It's almost as if the rear bearing needs to be pushed in further. I can measure the play, but it's so large that it's almost not worth measuring being that it is 0.125 to 0.250 by eye. I tried tightening the spindle ring on the back, but it won't draw it any further in.
    Instead of pulling it, maybe I'll soak it for a while in pb blaster and then see if I can get the ring to move the bearing race closer in.
  5. Likes Monarchist liked this post
    Oct 2012
    Virginia
    10,264
    5843
    4628
    Not the same mill, but there is a spacer in the similar place on my Burke.
    IF a previous tinker removed/left off a similar part, the threaded collar could have been run off the ends of its threads onto the unthreaded body.
    Trying to run it further in - IF that is the case - could worsen an already bad situation.
    I'd back if off at least enough to see if it still has either threads or clearance, first.
    The manual cited may help. And there are one or two of these in other PM members hands as well.
    The old chirurgeons mandate applies:
    "First, do no harm!"
  7. Likes spfrazierjr liked this post
  8. #6
    Apr 2017
    5
    Quote Originally Posted by Monarchist View Post
    I have taken the threaded collar off and pulled the spacer as well. When the spacer is in place, there are threads "under" it. By that, I mean there is room for the threaded collar to be threaded on further.
    As soon as the spacer and threaded collar hit the inner race of the rear bearing, it tightens the spacer into the inner race instead of "preloading" the spindle assembly.
    I am going to attach pictures to show the amount of movement front to back. If you flip between them, you'll see the large amount of movement.
    Attached Thumbnails Attached Thumbnails img_20170414_162841809.jpg   img_20170414_162844839.jpg
  9. #7
    Oct 2012
    Virginia
    10,264
    5843
    4628
    I see it. Good work!
    IF . .that were a Timken bearing - and I do not know if it is or not [1]... I'd suspect mis-matched inner cone/roller cluster and outer race.
    It was Timken's won't for Donkey's Years to provide for many shaft and bore sizes per roller cluster by offering their bearings as two separate components - pick and chose amongst a tribe of 'clans', then 'families' so to speak - of inner & outer to suit the need.
    If a previous Tinker not expert in that bearing selection system had gotten the wrong match, the depth would be off, and 'not only'.
    Page Two:
    The inner race could be tight up against a shoulder.
    Page Three:
    The FRONT bearing could be wrong-matched as well. That would position the rear wrong-ish.
    That said, d'you even know if it either/both front and rear IS/ARE Timken tapered-roller?
    Anything useful yet in the docs linked?
    [1] Tony's lathes.co.uk website says the Sheldon/Vernon mills used tapered roller bearings. That's 'probable' for all models, not 100% assured.
    The Burke #4 for example, originally used plain bearings, then Timken tapered Rollers, then for the 'high speed' spindle models, BALL bearings.
  10. #8
    Apr 2017
    5
    Page Two:
    Page Three:
    The linked documents helped and from them, I was able to find the manual for my exact machine! The bearings in my physical machine are tapered for sure, but I'm not sure what numbers are on them. The manual calls out 26822/26878 for the front and 2523/2580 for the rear.
  11. #9
    Oct 2012
    Virginia
    10,264
    5843
    4628
    Looks as if they are going to have to come out after all.
  12. #10
    Mar 2014
    Nebraska
    11
    I also have a Vernon Sheldon No. 0 mill. Mine is missing the arbor. Can you tell me what the arbor/spindle taper is?
    Tks,
    John
  13. #11
    May 2019
    CANADA
    Ontario
    Found some manuals on them online. There some mentioning on the tapers in the older one.
    Machine Tool Manuals
    The modification on the arbor from the same guy : Vernon #0 Horizontal Mill
