Sheldon No. 0 Horizontal Mill
Results 1 to 17 of 17
    Feb 2018
    Illinois
    8
    Default Sheldon No. 0 Horizontal Mill
    I'm looking for an original stand and a vertical head for a Sheldon No. 0 horizontal mill.
    Any help much appreciated.
    TIA
  2. Likes JackHB liked this post
  3. #2
    Jan 2005
    Victoria, Texas, USA
    4,792
    3441
    1351
    Good luck on finding a vertical head!!! They don't exists. Most of the ones that exists were adapted for use on a Sheldon mill. You have to adapt one to fit or make your own. I believe Sheldon use a vertical head off of a Diamond milling machine back in the day. Could be wrong.
    As for a base, you'll have to fabricate one to work for your mill unless someone has scrapped out one that you can get the stand off of.
    Ken
  4. Likes lvracing2 liked this post
  5. #3
    Jul 2005
    Northern New Jersey
    555
    2651
    72
    Quote Originally Posted by lvracing2 View Post
    TIA
    There were two different Rusnok heads appropriately sized for your machine. One of them was custom-made for the Sheldon. Model A-9033, with a matching Brown and Sharp #9 taper in the spindle. It mounted through the over on arm mount in the body of the mill, and was driven from the back of the spindle on a belt.
    It would be perfectly appropriate for you to use the Rusnok Model 70 Milling head, which used to double taper “Y “collets, and would mount to your overarm, 2 inches in diameter. You would lose about 2 inches of room below the head above the table, but you could also make a different doctor to stand it up a couple of inches higher.
    Surprisingly, I DID run into the head only last year. I put it on a Sheldon 0 I owned at the time, that didn’t have one, and sold it.
  6. Likes 4GSR, lvracing2 liked this post
  7. #4
    Virginia
    20,828
    7561
    12208
    TIA
    "What Bernie said". And it might be "a while" before you find one.
    Meanwhile, first vertical head you adapt need not wait nor stop that search if you need to USE one.
    We have carbides now.
    Folks have adapted Porter-Cable routers and Chinese air OR even liquid-cooled spindles with built-in ER chucks - no mechanical drive integration needed, just another power cord.
    Others, "Right here on PM", but not-only, have grabbed a value-for-money deal on a set of bearings and fabbed them from scratch -conventional power from the mill or belt drive from their own motor.
    There are also several right-angle heads in the used market - made for BeePees & clones - that could be re-purposed as a vertical head for a mill as small as the Sheldon.
    No advancing quill on any of these, let alone a powered one, but there's always the Z-axis.
  8. Likes 4GSR, lvracing2, itsmeBernie liked this post
  9. #5
    Feb 2018
    Illinois
    8
    Great info guys, much appreciated!
  10. #6
    Virginia
    20,828
    7561
    12208
    Helped me, too.
    I hadn't run a search in a few years.
    Some of those goods - search on "spindle", not head - are really inexpensive now.
    Many at around a hundred bucks complete with integral ER nose, either DC controller or VFD, and a mounting bracket.
    Cheap crap? Probably. What isn't these days?
    But at a price about that of a pair of decent boots - probably useful for a least "a while".
  11. Likes itsmeBernie, JBoogie liked this post
  12. #7
    Sep 2005
    Connecticut
    4,708
    631
    675
    For a mill that small, a Bridgeport head is probably out of the question - it would probably tip the mill over. They did make a Model H, which was basically a Model C specifically for the small Hardinge mills, but probably hard to find and even harder to find the oddball collets.
    Depending on how much power you need, you could adapt something like a Sherline headstock / motor unit. It's only morse taper 1, but there are collets for it and ER collet adaptors.
    A guy on ebay is selling a vertical unit for an Atlas milling machine (see pictures). That might give you an idea of what you can do with some fabricating.
    Steve
  13. #8
    Feb 2005
    Owl's Head, Maine
    2,465
    480
    729
    Quote Originally Posted by SteveM View Post
    For a mill that small, a Bridgeport head is probably out of the question - it would probably tip the mill over....
    Actually, it's a doable proposition. A piece of bent pipe, running in brackets bolted to the machine, lets the BP head, properly balanced, swing into and out of position with easy 1-finger pressure - no lifting, no danger of a toppleover. The mounting socket that mates the vertical head to the mill obviously fits over and clamps to the end of the overarm.
    A question to be sure you have answered to your satisfaction before you go down this road is, why do you want the vertical head? The Sheldon/Vernon is a very nice, dainty hor mill, but if you want to adapt it for drilling, cranking the handle round & round for punching a hole can get tiresome if not downright irksome compared to having a DP or a competant milling machine for doing the same job. The objection is less strong if all you want to do is a bit of side milling.
    -Marty-
    (sorry about the PITA sideways formatting of the thumbnails but I can machine up a pair of bevel gears faster than I can fix the problem, and maybe even faster than I could drill a decent batch of holes using the BP vertical head)
  14. Likes Paolo_MD liked this post
  15. #9
    Virginia
    20,828
    7561
    12208
    Quote Originally Posted by Marty Feldman View Post
    Sideways what? It's a thread on horizontal mills f'hems sake. Our "wetware" heads have to be able to rotate 90, even if Milling heads insist on remaining "vertical".
    Nicely done rig!
    ISTR reading that the BP head was only around 70 lbs Avoir?
    If I were to upsize that "pipe" to 2" heavy-wall "hydraulic" tubing, I might be able to steal the idea for the monster K&T head that's been adapted to 5200+ lbs Avoir of USMT "Quartet".
    It wants the 2 Ton engine hoist to get enough "reach" at present.
  16. Likes Rudd, 1yesca liked this post
  17. #10
    Sep 2005
    Connecticut
    4,708
    631
    675
    See Adam Booth's video series on the "parking attachment" for the K&T mill head. You can see one on Keith Fenner's mill, too, but Adam actually built one from scratch.
    Steve
  18. #11
    Virginia
    20,828
    7561
    12208
    Steve
    Adam may have built one from scratch, but not for this mill. Quartet is a weird Duck. Or perhaps Monotreme.
    He kindly carried the heads into the truck by hand when I picked up the Quartet from his old shop. Once home, I had to use machinery to get them back out!
    Stout lad, Adam is! One hand lift, he had even made it look easy!
  19. #12
    Feb 2005
    Owl's Head, Maine
    2,465
    480
    729
    Sideways what? It's a thread on horizontal mills f'hems sake...
    That's a very funny line.
    -Marty-
  20. #13
    Mar 2014
    Nebraska
    12
    TIA
    Does anyone know the approximate weight of the Sheldon Model Zero ?
  21. #14
    Jul 2008
    Waltham, MA
    425
    96
    I had a Sheldon mill that came equipped with a vertical head made by Porter cable. Pretty neat little compact head but it had no quill feed and when I found a Rusnok head, I rarely used the porter cable one. Coincidentally, there is a Porter cable head for sale in the toolong for sale section on PM
  22. #15
    Jul 2003
    savannah, jaw-ja
    1,921
    1712
    509
    IIRC the Sheldon 0 comes in around 900 pounds.
    I've got one of those Porter Cable heads, I never could figure a good way to get it spinning fast enough for the EM's that go in a BS7 collet. Or really, even a good way to drive it off the Sheldon spindle without messing with gears. I ended up getting a vertical which solved that issue.
  23. Likes itsmeBernie liked this post
  24. #16
    Aug 2010
    Canada
    340
    5
    108
    TIA
    Rusnok head ,b&s #9 collet chuck
    one in classifieds.
  25. #17
    May 2021
    New Hampshire
    67
    23
    I have a Sheldon #0 disassembled and the head as shown, also disassembled.
    img_20210610_095613.jpgimg_20210610_095706.jpgimg_20210610_095647.jpgimg_20210610_095803.jpg
    The post replaces the table for vertical foot.
    The head was used w/ the DC motor. Taken off and used separately. Not needed now.
