johnoder
- Jul 16, 2004
- Houston, TX USA
This relates to my 24" Lodge & Shipley Selective Heads from the teens/twenties, but many lathes use a form of this apron gearing.
L&S, who made very tough lathes, did not do great here, at least over the very long haul.
The shifting fork is the only thing there that takes the thrust of the double ended bevel gear.
As the fork wears, the bevel gears drift out of engagement.
Then there comes the day when a tough cut (lots of DOC, lots of feed) needs to be made and the dread "skipping tooth" sound comes from the apron.
Nothing broke, since L&S was a firm believer in soft steel gearing, but such silly goings-on did fold over tooth tips. Meanwhile, the fork got worse and worse.
Apparently, hardly anyone ever thought of reversing the lead screw, so never got much use out of the other end of the double ended bevel gear, and the other side of the fork.
Photos are here. I'll add to them as I finish machine these forks.
http://smg.photobucket.com/albums/v337/johnoder/24 X 168 LS/Older One/Fixing Shifting Fork/
John Oder
John Oder
