Nemesis
- Nov 7, 2015
- Southwest, MN
I recently purchased a 1948 Sidney Model 32 16" lathe. As I am going over it quickly, I am repairing any little items that I come across. One item that I came across is that the morse taper in the tail stock is extremely chewed up. The exterior of the quill looks good, but the interior took some real abuse. I have read a ton of the posts on here seeing people for and against using a reamer to clean up the tail stock. Generally I believe the consensus is using a reamer to clean up some light burs is OK, but trying to do any aggressive work on the taper in the tail stock with a reamer is frowned upon. Thoughts on this one and options or do I just run it:
