Sidney Model 32 lathe apron cross feed handle
Results 1 to 12 of 12
    Mar 2005
    Kansas
    89
    5
    Default Sidney Model 32 lathe apron cross feed handle
    I have a 1952 Sidney model 32 lathe, and the cross feed handle that engages the hirth clutch will not stay engaged. Does anyone have a photo of their handle that works properly?
    The problem could be the hirth serrated clutch, bearing clearances, handle adjustment, or wear on the handle itself that is causing the problem. The manual shows a sharp corner for a cam action when pulled, but mine has a radius.
    The handle in question is part number LW-189.
    Thank you!
    Neil
    Attached Thumbnails Attached Thumbnails 2e93dab3-5da2-454c-80cf-ff7e63515396.jpg
    Jul 2004
    Houston, TX USA
    30,463
    The manual shows
    Needs sharing. Did you know there is zero Sidney Lathe info on Vintage Machinery?
    Right now it appears you are the only one able to see that info.
  3. Likes neilert liked this post
    Mar 2005
    Kansas
    89
    5
    Quote Originally Posted by johnoder View Post
    I would be happy to scan and upload it. The manual is in great shape and has drawings of nearly every assembly.
    Jul 2004
    Houston, TX USA
    30,463
    Be a great addition. Here is VM's web page as to contributing pubs
    Scroll down to the 4th section
    VintageMachinery.org | Welcome
    Mar 2005
    Kansas
    89
    5
    Here are some diagrams of the lever handle.
    Mar 2005
    Kansas
    89
    5
    I'm wondering if this is enough wear on the handle to make it so it doesn't stay engaged. I may go ahead and add some material to create a sharp edge to see if that is the problem.
    Jul 2004
    Houston, TX USA
    30,463
    I wonder if the pins are sheared one side or the other?
    Before making it more "pointy", how about a .020" feeler each side to see if that does anything?
  9. #8
    Mar 2005
    Kansas
    89
    5
    I have the assembly on the workbench, and there isn't anything sheared. Really appreciate your help! I will try the feeler idea to see if it locks the cam in the engaged position. This is a newly acquired lathe and a unique clutch design, so I'm not quite sure how it is supposed to work.
    I'll try a few things and report back.
    Thank you!
  10. #9
    Aug 2004
    upper michigan
    304
    29
    I have a model 32, I had to adjust my handles, it’s been awhile but it seems if I remember right there is a exposed Allen screw that you adjust externally to get firmer engagement.
  11. #10
    Mar 2005
    Kansas
    89
    5
    Quote Originally Posted by Mike Hill View Post
    Yes, mine has the allen set screw as well. I tried every adjustment, but still no luck.
    Thank you- Neil
  12. #11
    Mar 2005
    Kansas
    89
    5
    Fixed.
    I ended up doing a CAD drawing to virtually rotate the lever on it’s pin. The drawing showed that the slight radius was enough to make it so the cam action couldn’t lock into place because there was no edge off of the axis of the pin. In the end I should have just trusted the drawing in the manual. Removing about 1/32” from the faces to create a sharp angled corner worked. Now the lever snaps into place and holds tightly. Hope this helps others with Sidney lathes.
  13. Likes James H Clark liked this post
  14. #12
    Apr 2004
    Riverdale, Nebraska, USA
    808
    104
    54
    Glad it worked. I figured you had deeper issues.
    I wonder how many cycles were required to round that cam off?
