partsproduction
Titanium
- Aug 22, 2011
- Oregon coast
For some reason I'd always believed silver solder would not work on cast iron.
Recently I decided to try it (because of something someone here said in a thread BTW), I took some ductile cast iron and cut it straight across with the vertical band saw, then painted both surfaces with black flux.
I already had silver solder sheet (56% silver content) so I cut a piece to fit the cut area after sanding the tarnish off. Then I painted black flux on that too, both sides, stuck it between the two pieces so gravity held the top onto the bottom piece,and heated it to a very low red temperature.
I couldn't believe I'd made my life so difficult because of an untrue concept, that the carbon content would stop it from tinning. The solder line between the halves is very thin, and I took it to the vise, clamped the bottom and adjusted a 14" Crescent wrench to see how much pressure it took to break the bond.
It would not break!
So I proceeded to repair the cast iron dividing head that got broken in shipment.
I guess I'm just too dumb to know I can't do that.
But seriously, I DID think it wouldn't work! Have any of you tried this? I just told an old machinist about this and he said it can't work, he's been in the trade even longer than my 35+ years, and is convinced only that low temperature "silver solder" will work.
The part I fit to the dividing head was ductile cast iron which I keyed to fit a slot in the broken casting after milling the break flat. I allowed just enough room for the silver solder sheet which is .005" thick.
Am I missing something here? BTW, I put this here because it's so common to have to repair old broken cast iron parts. I hope it's OK.
parts
It would not break!
parts
