I've not posted in a while and not sure if I'm in the right section. I've studied changing my Sebastian 13-48 School gear head lathe from 3 phase. I mean I've ran the studies from shop built Rotary Phase converter; Variable Frequency drive and installing a counter shaft for speed reduction. NOW, the latest is just installing a Harbor Freight 1 Hp dual voltage reversible 1800 RPM motor with a 2-1/4" diameter pulley as the spindle pulley is 6-3/4" approximately. I would nearly get my 600 spindle rpm that the book calls for. What this gets me is simplicity and I can start making chips MAYBE. I think I want to run a "B" width belt because I'll be right at minimum diameter for that Horsepower. Is there any experience with this small of single belt pulley? Do you think I be able cut anything or will the belt just slip? You guys Keep me goin' as I'm at the age there isn't much that keeps me interested other than my tinkering/dittling with junk stuff. For best friend and conversation I've a little long haired chihuahua dog, so, I don't need much else. bjr23
