Skinner Chuck Key - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 58 of 58
  1. #41
    Jun 2012
    Michigan
    14,096
    4810
    5083
    You could get an old throw-away car leaf spring and hammer/anvil forge it to be about 8" long and at fat at one end. Hammer and square punch out the square hole. and whack around to about 1/2", then resize the hole and oil quench. then heat it up and draw the hardness back to about 42-45R. then bench grind the part that needs go into the bore.
    likely it might only cost 10 bucks for an old leaf spring at the junkyard.
  2. #42
    Virginia
    20,855
    7561
    12219
    Quote Originally Posted by michiganbuck View Post
    F**k's sake? No need to start with Iron ore.
    Just order the stock square socket and use fire and hammer to alter the size.
    It is already decent steel in the needed shape, and the nearest stock sizes are right NEXT to the target in dimension.
    I'd still pull the existing pinions and reduce THEM to a stocked square size. It is fast and easy - there just ain't that much to remove.
  3. Likes digger doug liked this post
  4. #43
    Feb 2004
    peekskill, NY
    27,343
    6363
    Haven't a klew why you didn't simply use the standard-issue Bristo spline tools. ....
    62 year old me, could go back and explain that to 11 year old me, except my time machine isn't working right now.
    Like you never did stupid stuff when you were eleven years old....
    (also, back then the internet did not exist. I wasn't even aware of thomas registers)
  5. #44
    Jun 2012
    Michigan
    14,096
    4810
    5083
    could go back and explain something to 20yr, 30yr, and even last year me.
  6. #45
    Virginia
    20,855
    7561
    12219
    Quote Originally Posted by jim rozen View Post
    Only 62?
    So I was using TR before you were born? Mentor's company Purchasing Department had them. Another bud's Dad had Teletype service. Not to his home. He owned an AM broadcast radio station. API link. Western Union existed, already, too.
    LOTS of things worked rather well UNTIL ... Jim Rozen started doing stupid stuff.
    No fear.
    We'll put it on your tab.
    Manage to bankrupt your contrarian arse, and that could be one less brain-dead Marxist voting twice, next election.
    Long arms, Bristol Wrench have. Splined, too!
  7. #46
    Jul 2001
    North Carolina
    2,204
    257
    551
    If you have an odd size male square,
    I would try a 12 point socket.
    If you have an inch and metric set
    you will likely find one that is a
    good snug fit. I have a Skinner
    chuck that I use on my Brown and
    Sharpe #13 grinder, a true grinder
    chuck with the sealed center. Anyhow
    I use a 7/16" 8 point socket and a
    tee wrench. Fits perfect.
    -Doozer
  8. #47
    Feb 2004
    peekskill, NY
    27,343
    6363
    To the OP - what's the desired OD of the wrench, where it fits into the chuck body?
  9. #48
    Virginia
    20,855
    7561
    12219
    Quote Originally Posted by Doozer View Post
    -Doozer
    EIGHT POINT is righteous.
    12-point can bugger the p**s out of it. Seriously. Don't-even...
    "Somewhere.." I have several 1/32" sized 12-point and one or two in 1/64" sizes that were custom items "back in the day" some among us figured we would adopt 32nds and 64ths and NOT ever have to mess with that newfangled "Metric" BS.
    Dumb move, as it turned out.
    Metric was dead-easy if we simply bought two separate but waaaay smaller count sets of wrenches and shifted MENTAL gears to suit the wehicle.
    So we did that instead.
    Then you ran into foolishness such as the Denso A/C compressor mount on the '84 "Franco-American (Japanese)" Jeep Wagoneer four-banger.
    Barefoot-poor AMC used whatever leftovers the "Big Three" had remaindered in any given week! Might be GMC parts, Ford parts, or MOPAR!
    Between brackets and braces, 4 of 9 fasteners were metric, the other five were US! Just for the A/C compressor.
  10. #49
    Feb 2004
    peekskill, NY
    27,343
    6363
    I need a project. I'd just make the darn thing to end this thread - if he provided the OD mentioned above....
  11. Likes neanderthal mach, dundeeshopnut liked this post
  12. #50
    Jan 2005
    San Francisco Bay Area
    290
    35
    I have the brother chuck to the OP's: a 6" Skinner 3 jaw with both a scroll and independent adjustment of each jaw. The scroll pinions have a 7/16" male square so I milled a square in the end of a piece of 3/4" round steel. Took about 45 minutes including making the handle. Piece of cake and I am not a particularly fast worker.
  13. Likes MyLilMule liked this post
  14. #51
    Jan 2021
    Ohio
    220
    The OD is 1".
    I don't look at this thread very often since farktard won't just STFU and go away.
  15. #52
    Virginia
    20,855
    7561
    12219
    Quote Originally Posted by lathehand View Post
    That's how s**t is meant to work.
    You had a stock size a person could "just buy". So you had to go and make one to fit.
    HE has an odd size not easy to "just buy". So he is compelled to buy one that DOES fit!
    Rozen-San - given the OD - will nail the OD. But make the square socket the wrong size.
    Go figure it's a damned good job we ain't runnin' the Government?
  16. #53
    Jun 2001
    St Louis
    19,460
    2448
    3706
    Those things were made in most sizes. I have an assortment in various sizes in a drawer somewhere. Every time I think about getting rid of them I think again about the ones now in use around here.
    I have a 4 jaw with those knuckle-busters, and when I needed a wrench for it, I found it in the drawer. Ditto for the table clamp on the old Greenfield grinder. And a number of other things.
    Heck, I even have a dogbone ratchet with 4 sizes of square socket. Seems like they are everywhere when you do NOT need them. Which is when I bought the lot.
    If you just gotta make one, OK. Otherwise...........
  17. #54
    Feb 2004
    peekskill, NY
    27,343
    6363
    ... But make the square socket the wrong size.
    The size of that square's been established though. 15/32, right? Easy to shaper it to size.
  18. #55
    Virginia
    20,855
    7561
    12219
    Heat and hammer are cheaper and faster. And I have both of a 12" shaper and a 7" slotter.. mills.. drill presses. even a panto-engraver that could "carve" at it.
    NONE OF WHICH are remotely worth the BOTHER of setting up!
    It ain't a Grob spllne.
    Only a ham-sandwich-ignorant SQUARE HOLE 1/32" off a COMMON store-bought size!
    FIX the obsolete choice OF said size .....by altering the "PROBLEM side" - the pinion ends need to be trimmed a skosh..are probably raggedy ANYWAY..
    and END of "problem" ever-after.
    "Store bought" becomes the solution.
    BFD.
  19. #56
    Oct 2005
    22,400
    Quote Originally Posted by MyLilMule View Post
    Qty (0) f*cks given.
    Meh. Not in a rush.
    Last time I even remotely try to assist you in any way.
    It appears OP has no intention of even attempting this little project, more so this thread was started to get the OP's
    website address splattered as many times as possible here, thereby driving "google hits" .
  20. #57
    Jan 2021
    Ohio
    220
    Don’t know why you’re getting all worked up. It was a joke.
    I was merely looking for information. I have it now. Thank you to all that provided some assistance or ideas.
    I have no idea if I will make one, buy one, or just sell the dividing head (highly unlikely). My Bridgeport is still in pieces as I have decided to just do a full tear down and rebuild.
    But I do like to try and plan ahead.
  21. #58
    Virginia
    20,855
    7561
    12219
    Ah S**t!! Devious skinner-dipping pranksters!
    If we had knowed you was a BirdPort flunky?
    We cudda just tol you to go f**k yerself in the BEGINNING!
    PS:
    That was a "joke"
    Well.. depending on time-zone.
    Odd days, even days thing... I do like to try and plan a head, y'see...
