Smart&Brown Model L capstan lathe
Page 1 of 4 123 ... LastLast
Results 1 to 20 of 69
    Mar 2013
    Surbiton, surrey, UK
    1,597
    1937
    995
    Default Smart&Brown Model L capstan lathe
    New to me recently. The plan is to go through it, do what needs doing and get it making parts
    According to tonys site, its an early model as it has an aluminium base.
    Am on the look out for any tooling in the UK btw.
    Cheers
    D
    Mar 2013
    1,597
    1937
    995
    First job is have a look at the turret, looks simple enough.
    Slides still in great shape despite the grease love. Will just give the top surfaces a cross cut for oil retention.
    The tapers the turret mounts on are in great shape as is the locking thingy.
    Not sure how the screw stop pin got so bad but ill face that off and put a flat on it. Unless theres a better idea here.
    Same for the this washer that sits in front of the worm. Will make a new one.
    The bushings for the hand wheel were hanging so made em.
    And in their new home.
    The tapered pin that holds the worm dog and drive gear was broken. Wouldnt budge and i didnt want to smash on it to hard so I used the DHC to have that out.
    Reamed the shaft/dog and gear for the new pin, as it should be. The gear was being held in place a grub screw and the dog with what was left of the old pin.
    Should be back together today with any luck, tool slide next
    Jan 2007
    Norfolk, UK
    18,797
    14317
    14358
    If my experience of S&B Model L's is anything to go by you will like your new toy.
    Nice one Mate
  4. Likes cutting oil Mac liked this post
    Apr 2006
    Manchester, England
    8,254
    1200
    5229
    Regarding the brass bushes we always drilled and tapped them down the joint line and fitted a grub screw just to make sure they stayed put.
    Regards Tyrone.
    Mar 2013
    1,597
    1937
    995
    Cheers Sami . Had some fun n games getting it back together (note to self, mark gear timing! lol), and found out the turret lock likes a light oil, the fits are too close for anything like way oil. Works like a champ now though
    Tyrone, ive heard of that type of 'key' before but cant remember the name , sounds like a good idea for a critical or buried bushing. Plan to use that type of key to secure the nut im gonna make for my DSG tailstock quill. For the model L I made the bushings OD .001" or so oversize and pressed them in, I turned the ID to a nice slip fit but needed to ream them after id pressed them in, guess they crushed down a little. I think theyll be ok
    Cheers
    D
    Norfolk England
    2,260
    2611
    1672
    Quote Originally Posted by Demon73 View Post
    Cheers
    D
    You need to mention shank dia. of tooling. At a guess 5/8",look for screw machine tooling. You could also speak to Frank at Autos GB. He is in Melbourne Derbyshire.
    Mar 2013
    1,597
    1937
    995
    Quote Originally Posted by camscan View Post
    Its 3/4" shank on this on one. Have you got a link or something for Frank? Found nothing for Autos GB.
    Cheers
    D
  9. #8
    Mar 2013
    1,597
    1937
    995
    Ive just had the front cap off the spindle and it aint good. The cap just slides over whats left of the threads on the spindle, someones used grub screws to hold the cap on, it uses push collets so not hard to guess who won that battle! Im even wondering if the cap is a different thread.
    A file wont touch the spindle so if I want those threads back???
    Im gussing spindle out, hard turn threads deeper and live with grubscrew damage, make a new cap.
    or knock off the threads, weld it up, turn new threads, hope it doesnt move,,, too much ..
    Better ideas welcome.
  10. #9
    Feb 2005
    Owl's Head, Maine
    2,238
    360
    602
    Nicely illustrated post, Demon. Sounds like you're going to wind up a happy man.
    Re your tooling request, you might try a Wanted in Tony's listing.
    -Marty-
  11. #10
    Norfolk England
    2,260
    2611
    1672
    Cheers
    D
    01332864850,good luck.
  12. Likes Demon73 liked this post
  13. #11
    Jan 2007
    Norfolk, UK
    18,797
    14317
    14358
    ''Better ideas welcome. ''
    Hard turn off threads to clean surface, m/c up OD threaded sleeve and Loctite in place.
  14. #12
    Mar 2013
    1,597
    1937
    995
    Quote Originally Posted by Marty Feldman View Post
    -Marty-
    Thanks Marty, be happy when its done lol.
    Quote Originally Posted by Limy Sami View Post
    Is Loctite is it really that good? Not much room for a sleeve, something like .050" a side if I leave the nose OD as is (.100 or so difference from cap id to nose od). Have done a bit more investigating, the threads (24 tpi) are soft, the area in front isnt fileable. The cap is fileable.
    It could be so easy lol.
  15. #13
    Jan 2007
    Norfolk, UK
    18,797
    14317
    14358
    Run a few tests on Loctite and see what you think ??? …………..IME use the correct brew of Loctite, follow the instructions and it don't half take some shifting.
    As for the soft parts, they're a game changer and you're pretty much home and dry
  16. Likes Demon73 liked this post
  17. #14
    Mar 2013
    1,597
    1937
    995
    I like the sound of that mate!
    If Im having to get into the headstock, I might pause and have a good think on how I want this thing to work. Having a set up for bar work is a must. Will get my head around how the collet closer works cos as things were, it had a bung in the end of the spindle which im not so sure needs to be there. I need some schooling on the ways of the capstan lathe
    Heres one that got away, a pile of gear went with it .
  18. #15
    Aug 2008
    Sussex, England
    3,373
    12
    734
    I've done the weld-up and re-cut threads thing way back on a similar, albeit not lathe, spindle repair. Managed to keep things straight but result was "OK I suppose" at a charitable best with a heavy dollop of fix on Sunday ride on Monday. But it worked. If you are planning on building up perhaps metal spaying would be worth investigating.
    Loctite is that good. If you can trim the plain part down too it will pretty much double the adhesive area. Its not gonna pull off. Far, far stronger than the threads. On this sort of job there is a minimum thickness for the "tube" section under the threads to avoid weird stress issues with the thread. I imagine something over half the thread depth underneath will be fine. Loctite may have an application note about minimum sleeve thicknesses.
    Clive
  19. Likes Limy Sami, Demon73 liked this post
  20. #16
    Norfolk England
    2,260
    2611
    1672
    I need some schooling on the ways of the capstan lathe ;
    Does that mean you have no experience of capstans?
  21. #17
    Mar 2013
    1,597
    1937
    995
    Cheers Guys, thats 2 votes for Loctite so ill order some up and give it go. I messaged Loctite UK and they suggested 638 and clean with 7063. Good point about extending the sleeve, it adds surface to the joint. Will likely keep the 24tpi over the standard 8tpi in case I want to grip a collet with the cap rather than the closer. Could make the thread od a bit larger too if needed, I dont mind making a new cap etc.
    Ive some play in the rear bearing (.004" axial and .005" endlfoat) so have to look into that, the rear bearing is opposed ball races the front bear is an adjustable bronze bearing. With luck ill find some shims that let me adjust things.
  22. #18
    Mar 2013
    1,597
    1937
    995
    No experience with capstan lathes im afraid, ive a WS turret lathe operator book, whole new world of stuff in there.
  23. #19
    Norfolk England
    2,260
    2611
    1672
    Have a word with Frank,he will have all kinds of toolholders. You will need floating drill holders,rollerbox and V steady turning tool holders,a tap holder,a button die holder,and if your luck is in a Coventry diebox. Tell him they are all OG turret size,he will understand.
  24. Likes Demon73, Limy Sami liked this post
  25. #20
    Jan 2007
    Norfolk, UK
    18,797
    14317
    14358
    Camscan, I've already spoken with Demon and am going to sort through my collection of capstan tooling for 3/4 shank stuff, and / or those that can easily be modified.
    During out chat he told me he'd some dieheads.
  26. Likes Demon73 liked this post
