Smart&Brown Model L capstan lathe - Page 2
Page 2 of 4 FirstFirst 1234 LastLast
Results 21 to 40 of 69
  1. #21
    Norfolk England
    2,285
    2631
    1699
    Quote Originally Posted by Limy Sami View Post
    Camscan, I've already spoken with Demon and am going to sort through my collection of capstan tooling for 3/4 shank stuff, and / or those that can easily be modified.
    During out chat he told me he'd some dieheads.
    Well he's a lucky fellow then. Forgot to say that the tapholder should be a releasing type.
    No, he's not a lucky fellow because he spoke to you,any idiot can speak to you,(had to,just had to). He is lucky to have dieheads.
  2. #22
    Mar 2013
    Surbiton, surrey, UK
    1,622
    1997
    1039
    I think most of the die head stuff I have will be too big, I'll dig em out and take a look when I get a mo.
    Have turned a gage for the spindle threads, it's about as nicer fit for the cap as could hope for, I intend to keep the same size/tpi but will make it longer, leaving say .100" on the nose. Is gonna be one skinny sleeve with around .040" under the threads. I've some EN19T that I plan on using.
  3. #23
    Jan 2007
    Norfolk, UK
    18,952
    14454
    14531
    Quote Originally Posted by camscan View Post
    Cheeky little sod!
  4. Likes Kjelle liked this post
  5. #24
    Feb 2004
    Baltimore, MD, USA
    4,027
    292
    588
    Thats a happening little capstan lathe!
    My Wade is a similar size, also 3/4" shank. The smaller 2 sizes of Coventry die heads should fit yours just fine, I opted for making a new shank for my Conventry, an ebay score in fantastic shape but had a 1" shank.
    I've found drill chucks take up a lot of axis, my prev owner liked them so I have a pile. What works well as a quick expedient is to take a short length of 3/4" TGP or at least pretty smooth bar, drill it through for the size of drill you want and fit a grub screw that is below the surface when clamping the drill. Then you fit the assembly directly in the capstan bore; gets you a minimum length projection, with the cost of ending up with lots of the buggers in the toolbox and you have to find the one you want. Its also not a floating arrangement so quite sensitive to misalignment of capstan to spindle bore.
    I'm a fan of the Boyar Shultz box tools, though have a few Brown&Sharpe also. Its a shame about your spindle nose, OTOH when using the machine for conventional turret work I've not yet ever mounted anything to the spindle threads; all in collets.
    You have any preferences for coolant? I run cutting oil diluted with 0W spindle oil so it pumps and drains well. It helps with repeatability, particularly with dicey tool setups, but does tend to make a mess.
  6. Likes Limy Sami, Demon73 liked this post
  7. #25
    Mar 2013
    1,622
    1997
    1039
    Thanks for the info Greg. Unfortunately I need the cap to use the dead length collets that came with the machine. Although open to suggestions for other collet setups etc.
    Cheers
    D
  8. #26
    Feb 2004
    Baltimore, MD, USA
    4,027
    292
    588
    Yeah, looked more closely after I posted- that cap needed for sure. I think its well worth getting fixed up to work properly, my Wade uses conventional pull-in collets which always puts the workpiece at risk of pulling back a bit when the collet is closed. It usually requires a hand to ensure the piece doesn't creep away from the feed stop and somewhat fussy adjustment of collet tension.
    I mounted a "0XA" sized import toolpost w/ holders on the production slide, helps to put the form tool on one end and a parting tool on the other. Quite envious of the Hardinge spindle-mounted parting slide, there are never enough tool positions lol
  9. #27
    Mar 2013
    1,622
    1997
    1039
    Well, its on there. I cleaned with their 7063 and slipped it on with 'a rotating action' using Loctite 638. I was gonna try and do a couple test pieces, but decided its much its much easier to just blame Sami if it dont work
    Ive seen a Britan lathe that has 1 1/4 through the spindle, im trying not to buy it honest
  10. Likes sfriedberg liked this post
  11. #28
    Jan 2007
    Norfolk, UK
    18,952
    14454
    14531
    Quote Originally Posted by Demon73 View Post
    My shoulders are broad.
    if Demon thinks/finds a capstan's a bit confusing, .....a Britan will bend his brain out of shape - for starters they run ''backwards''
  12. Likes Demon73 liked this post
  13. #29
    Mar 2013
    1,622
    1997
    1039
    lol, I find everything confusing!
    Anyways, ive got a phone and im not afraid to use it!!
    Crappy quality video but they look like amazing little machines, if a bit of a bugger to set up.
  14. #30
    Norfolk England
    2,285
    2631
    1699
    What material do you intend to cut with your phone?
    The Britain is/was a nice machine and once you get your head round it you will love it. Go on,go and get it.
  15. Likes Limy Sami, Demon73, Tyrone Shoelaces liked this post
  16. #31
    Mar 2013
    1,622
    1997
    1039
    Youre not helping! lol
  17. #32
    Apr 2012
    New Zealand
    676
    166
    193
    There's some tooling here. Looks like you found the slippery slope...
  18. Likes Demon73 liked this post
  19. #33
    Jan 2007
    Norfolk, UK
    18,952
    14454
    14531
    Oh yes he is …………...…..''look in to my eyes, …….yes that's it, ………...you want that Britan ……………..you do,...…………...you know you do, ………...that's it, all nice and sleepy,...……...now just click the mouse, .................there there, ...didn't hurt a bit - did it.''
  20. Likes Demon73 liked this post
  21. #34
    Mar 2013
    1,622
    1997
    1039
    Pair of enabling monkeys the both of ya! lol
  22. #35
    Norfolk England
    2,285
    2631
    1699
    Did he call us monkeys dad? When he gets back from picking up the Britan go over there and lump him one.
  23. #36
    Jan 2007
    Norfolk, UK
    18,952
    14454
    14531
    He's bigger than me and I can't run as fast as I used to, so I will NOT.
  24. #37
    Norfolk England
    2,285
    2631
    1699
    I think it's worth you getting hurt so I can save face. Go on Dad,lump him one.
  25. Likes Demon73 liked this post
  26. #38
    Jan 2007
    Norfolk, UK
    18,952
    14454
    14531
    When I won't be able to sign your pay cheques?
  27. Likes camscan liked this post
  28. #39
    Mar 2013
    1,622
    1997
    1039
    Have been mad busy last couple days.
    Just had a quick look at the rear bearings, opposing ball races that take care of end loading and float. Seems I need around .007" between the outer races to tighten things up, ill make a stack that gives me some room either way.
    Anything that improves what I had is welcome
  29. Likes Limy Sami, Greg Menke liked this post
  30. #40
    Norfolk England
    2,285
    2631
    1699
    Speaking to an old customer who became a friend today. He is setting a Britan to centre(yes CENTRE) drill and tap some old railings which have rusted through at the bottom. For those of you that know these are for houses which have a basement in the CENTRE of London. Trust me, you couldn't afford the railings, don't even think of buying the house.
