So I bought an 8" Southbend lathe today
Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    Sep 2019
    New Jersey
    17
    Default So I bought an 8" Southbend lathe today
    I plan to tare it all down, clean, and paint. No major reconditioning at this point (as if I'm an expert). Would like to hear a critique of ths purchase (300$, no formal jackshaft, no extra change gears, decent shape, not perfect, 1 maybe 2 3 jaw chucks, a few other odds and ends, motor). Especially would like to hear from present or past owners of such a lathe. Man'd around 1932.
    Jul 2010
    Virginia, USA
    3,548
    87
    686
    Lack of change gears is a real drag. I would avoid a tear down and paint if possible. There are lots of taper pins and thin castings in this lathe. It is easy to break something. Unless the paint is peeling off into little razor blade flakes, I'd just clean it up and use it.
    allan
  3. Likes stevewatr liked this post
    Jan 2005
    Victoria, Texas, USA
    4,336
    2727
    1160
    We need pictures!!! Can't tell you anything without pictures. Also the serial number, which is stamped between the Vee's at the tail stock end of the bed. BTW- South Bend Lathe did not build a 8" lathe that i'm aware of. They did build hundreds of thousands of 9" lathes over the years.
    Jul 2007
    Florida
    807
    97
    420
    Quote Originally Posted by Chris2019 View Post
    No change gears is a significant draw back. By the time you spend money for the change gears you need this is not a bargain
    CarlBoyd
  6. Likes _boris_ liked this post
  7. #5
    Jun 2019
    South Dakota
    71
    16
    19
    sounds like a decent buy. about tearing it down, My dad has bought two S.B. lathes and on both the oil wicks had build up in them that prevented oil to wick properly, which we discovered before any damage occurred fortunately. on most south bend lathes all of the oil is wicked rather than gravity feed. I don't believe replacement requires total tear down. use plenty of good quality oil and it should be a good little lathe for you. complete manuals and exploded views of the parts are readily available for your machine. Checkout vintagemachinery.org they've probably got the manuals for free download. enjoy your new investment!
  8. Likes mllud22 liked this post
  9. #6
    Jul 2004
    Houston, TX USA
    31,262
    Thanks to Mr. Wells, we have this from 1932
    http://www.wswells.com/data/catalog/...t_1932_8jr.pdf
    Only "manual" I am aware of is like so
    http://vintagemachinery.org/pubs/1617/5795.pdf
  10. Likes mllud22 liked this post
  11. #7
    Oct 2018
    Maryland
    81
    5
    15
    I just bought the 1966 version of How to Run a Lathe if interested.
  12. #8
    Apr 2007
    Minneapolis, MN
    1,620
    124
    675
    Quote Originally Posted by 4GSR View Post
    Yes on needing pictures.
    South Bend did build an 8 inch swing lathe at one time.
    Rob
  13. Likes 4GSR liked this post
  14. #9
    Sep 2016
    Missouri
    881
    781
    272
    Quote Originally Posted by hvnlymachining View Post
    These lathe's require consistent daily oiling. If it's been sitting for years a teardown is sometimes needed. You can work at getting oil o flow but old oil can get hard.
    South Bend Lathe Works - Publication Reprints - How To Run A Lathe 55th Edition | VintageMachinery.org
    two part book.
    South Bend Lathe Works - Publication Reprints - How To Run A Lathe | VintageMachinery.org
    South Bend Lathe Works - Publication Reprints | VintageMachinery.org
    The SBL Workshop
  15. #10
    Sep 2019
    New Jersey
    17
    sorry for the delay. And the lighting wasn't fantastic:
  16. #11
    Sep 2019
    New Jersey
    17
    and a few more:
  17. #12
    Sep 2005
    West Virginia
    4,109
    473
    Quote Originally Posted by Robert Lang View Post
    Rob
    Yep, the 8" Junior. I had one until recently. They are light-duty, but well made.
    Andy
  18. #13
    Aug 2013
    Worcester County, Massachusetts
    937
    362
    124
    Wow, I think I just picked up the same lathe!!
    I was picking up a rare Hardinge 2nd operation lathe that was in bad shape, and missing parts, so while negotiating i asked if he had any other items, and he says "well, i do have another lathe I'm getting rid of...."
    He takes me out in the back yard to a plastic tarp shed, and 20 minutes later I'm loading both lathes in the bed of my pickup.
    Small world. Btw, I haven't decided the fate of either lathe yet.
    Steve.
    Sent from my SM-J737P using Tapatalk
  19. Likes M.B. Naegle liked this post
  20. #14
    May 2009
    Canandaigua, NY, USA
    3,032
    151
    1397
    I sing the praises of change-gear lathes for anybody doing weird and technical stuff. As I get older, I curse small dials.
  21. Likes neanderthal mach liked this post
  22. #15
    Sep 2019
    New Jersey
    17
    @ Stevewatr - I'm only in NJ dude! LoL. Can I ask though if you're 8 came with a complete set of gears? If so, please provide photos.
    I have a couple of ideas on how to supplement (or in plastic replace the entire gear train). What's there may be sufficiently worn that meshing with a new set of gears my not be the best idea. All I have in my arsenal that would facilitate constructing new gears (or molds) is a little "headless" EMCO F1 mill. A horizontal mill is better for gear cutting I imagine. I won't disclose the details but there's a poor man's version of 3D printing that I could employ to make molds, but not gears.
  23. #16
    Sep 2010
    moscow,ohio
    6,386
    651
    2128
    provide tooth count and outside diameter of the big gear on the bottom and we can determine what gears will work.
    You currently have the fine feed gears in place and are fortunauate to have them, you just need the threading change gears....your chart will tell you the tooth counts you need......just need to determine the diametral pitch.
  24. #17
    Jul 2004
    Houston, TX USA
    31,262
    You can tell us and yourself what you have
    Any change gear known to be for your lathe you do have can be measured
    Count teeth
    Add two to the count
    Measure OD with mic
    Divide that O.D. in to the count plus two
    Example:
    32 teeth, 2.125" O.D.
    34 divided by 2.125 = 16 diametral pitch - often written 16 DP
  25. #18
    Aug 2013
    937
    362
    124
    Nope, only gears it came with are what's on the machine right now.
    I have a stack of change gears for a craftsman 109, if they check out diametrically, I'll modify the bores and make them work. If that fails, I'll probably sell the lathe or part it out.
    Steve.
  26. #19
    Sep 2019
    New Jersey
    17
    Although I can imagine instances where parting out a rare lathe could be viewed as philanthropic, the suggestion kind of skeers the jeepers out of me. Just make sure you raffle off those parts that aren't easily lost, Like the headstock. You may wind up getting stuck with the bed, but I'd be interested in the bed, so I imagine maybe other delinquents may also.
    I don't know what you have into it, but I'm sure a lot of people would love an 8" SB. It's a good size for me, but it's a collector's lathe more then anything. A 9" is way more convenient, as parts and attachments are way easier to source.
  27. #20
    Aug 2013
    937
    362
    124
    In all honesty, I have not looked closely at it since I brought it and the hardinge home a few weeks ago. Other than being confident it's a south bend, and seeing it's pretty small compared to my 12", I'm not yet sure what size it is lol. Time to take some measurements and pictures I guess!
    Steve.
