So I bought an 8" Southbend lathe today - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21
    Sep 2019
    New Jersey
    17
    Quote Originally Posted by mllud22 View Post
    These lathe's require consistent daily oiling. If it's been sitting for years a teardown is sometimes needed. You can work at getting oil o flow but old oil can get hard.
    I can understand the problems with oil, the lathe behind the SB, a Prazi SD-400, gets a crunchy spindle when it's cold. But why should this lathe be any different from any other SB, who's spindle runs in the cast iron headstock bore (and I suspect that is the case, although it's purported there are exceptions, bronze bushings, even babbitt)?
  2. #22
    Sep 2016
    Missouri
    781
    668
    221
    Quote Originally Posted by Chris2019 View Post
    It isn't any different. Sometimes if a lathe with oil wicks sits for a long time it's hard to get oil flowing again
    The wicks in the apron are exposed to swarf ,chips and dust which oil works like a magnet to attract. If a lathe came from a really dirty environment new wicks could be a good idea. Considering its age. Just making sure clean oil gets to all the intended parts. Your lathe looks pretty clean.
    A lot of guys re-wick and clean oil passages to be confident it's all clean and getting oiled.. It's hard to tell if previous owners cleaned around the gits oil cup before lifting the lid to oil.
  3. #23
    Jul 2004
    Houston, TX USA
    29,665
    '32 catalog linked above says cast iron - of the head stock
  4. #24
    Sep 2019
    New Jersey
    17
    Quote Originally Posted by johnoder View Post
    Yes, and as I was going by the info.on lathes.co.uk, I thought there was the possibility of a different bearing type. Scared the daylights out of me! Nothing against babbitt or bronze, the nice thing about those types os they're replaceable.
    Thanks for all the enthusiastic replies thus far.
  5. #25
    Sep 2010
    moscow,ohio
    5,918
    579
    1893
    post up those gear specs...include the face width(how "thick")and bore size.
  6. #26
    Sep 2019
    New Jersey
    17
    5.225" diameter on big gear, 92 teeth. The rest is coming.
  7. #27
    Jan 2019
    Virginia
    135
    50
    30
    Atlas/Craftsman gears aren't going to work anywhere in a South Bend.
  8. #28
    Sep 2010
    moscow,ohio
    5,918
    579
    1893
    18DP....they "might" be the same as workshop series 9".....which are 18DP x 3/8" thick x 9/16" bore IIRC.
  9. #29
    Sep 2019
    New Jersey
    17
    9" gears will be too expensive. I'll investigate making my own, in plastic initially.
  10. #30
    Jul 2004
    Houston, TX USA
    29,665
    Equals 18 DP - like in Post #17
