Steady Rest Modification Plan
Results 1 to 18 of 18
    Dec 2016
    New York
    657
    9
    233
    Default Steady Rest Modification Plan
    So i bought a steady rest that was close to the right dimensions for my mid 30s RP gear head lathe. Basically the "V" slot on the steady rest needs to move toward the center of the steady by about 1".
    My plan is as follows:
    Cut out a one inch section of the base approximately at the location indicated between the small dividers.
    Cut the brace on the "V" side at the interface between the brace and the lower half circle as indicated by the pencil points.
    Establish horizontal alignment of the base pieces and braze the base together on the bottom and braze the brace to the lower half circle.
    This plan would provide the necessary side clearance between the base and the saddle and would register the center of the circle on the center-line of the spindle.
    I'm feeling like the hardest part is going to be to establish alignment of the base and that the worst thing that i would have to deal with is to mill the bottom flat and shim it up.
    Please let me know what you think.
    Mark
    Attached Thumbnails Attached Thumbnails img_20210112_181646424.jpg   img_20210112_181641323.jpg   img_20210112_181617368.jpg
    Feb 2006
    Indiana
    13,620
    770
    4440
    Heating a loop-shape of cast iron to brazing temperature will usually result in the iron cracking as it cools down. I suggest you think of a solution that does not require heat.
    Larry
  3. Likes cyanidekid, michiganbuck, rj1939 liked this post
    Jun 2016
    New York
    1,976
    1409
    943
    find one that fits the ways, or fabricate from steel and machine it to fit. welding/brazing a casting, and thinking it has a prayer of lining up with the ways is a fools errand!
    Jan 2007
    Norfolk, UK
    20,929
    16374
    16792
    + another on what they said.
    Jun 2012
    Michigan
    12,822
    4356
    4600
    What if you just milled the steady base straight across the bottom flat and then made a sub-base fitted to your lathe and bolted and dowelled to the steady?
    With the parting line filled and panted it would look original.
  7. Likes Limy Sami, CalG, rj1939, James H Clark liked this post
  8. #6
    Feb 2020
    107
    40
    mill the base off flat
    bolt what you need to the bottom
  9. Likes michiganbuck, Limy Sami, CalG, garyphansen liked this post
  10. #7
    Mar 2020
    CANADA
    Quebec
    168
    300
    111
  11. #8
    Virginia
    17,408
    7561
    11206
    Quote Originally Posted by dundeeshopnut View Post
    Don't over-think it. It does not "traverse". It isn't the cross slide bearing a cutting tool with cutting forces to be managed. It may have been USED just the "hacked" way it is now.
    If you have a means of aligning it precisely, you could cast a filled-epoxy in that gap. Or dowel-pin in a block of shiney-wood, THEN mill the Vee. Not even "soft" solder heat on the dance-card.
    The "job" of the inverted vee is to align it quickly each go without need of digging out a clan of measuring tools to manually set it.
    Old Skewl hand wouldn't even bother - just start snugging the tips and checking alignment for "feel" of a comfortable balance. Clamp 'er. Touch up the tip positions. Make chips.
    Once you activate the under-ways clamp, there should be PLENTY of resistance to unwanted movement.
    Adjust the tips correctly, even if their "frame" is not perfectly centered, it just SITS where you clamped it, rotating stock sliding or rolling with minimal argument.
  12. #9
    Jan 2005
    The Netherlands
    6,456
    337
    1837
    Like said before Mill the bottem flat and ad a subplate Or better prehaps Mill a groove and bolt a block with a V to it
    Even if the steady ends up a bit high it does not matter to much
    Peter
  13. #10
    Jun 2012
    Michigan
    12,822
    4356
    4600
    With having access to a surface grinder and the ability to dress angles to a wheel for the V notch angles the subplate would be an easy task with fitting it to the lathe bed, finish grind it to height, and then just scribe it to centering the steady to mark it as it holds a slug in the lathe chuck, and bolt it in that place.. no fancy measuring needed.
    Yes, cutting the subplate V notch could be done on the mill or by using a vise on the lathe with it having an end mill cutter in the spindle.
  14. #11
    Dec 2016
    New York
    657
    9
    233
    Thank you to all who responded to this thread. I've decided to cut my losses and return this to the ebay seller. I'll take it in the shorts on shipping but so be it. After some thought, this thing would take a bunch of work to get the required side clearance and the net result would be to reduce by one the world wide inventory of antique steady rests and a one bodged up one.
  15. Likes Riderusty liked this post
  16. #12
    Mar 2020
    CANADA
    Quebec
    168
    300
    111
    I think you are making this harder than it is. As long as it is square to the spindle and somewhat centered on "Y and Z" it will do it's job admirably. 2 or 4 screws to hold your new "foot" to the existing legs [could even allow for some adjustment or fine shimming there] and your done. Curious. Since we both have the same rest, do you know the maker? My query came up empty.
  17. #13
    Feb 2004
    peekskill, NY
    26,213
    5772
    Quote Originally Posted by cyanidekid View Post
    I had to 'shrink' a tailstock from a 9" southbend, to make it fit an older Potter lathe, which I had bought sans tailstock. Key here was to drill two holes up from the underside before cuting the piece out of the risers. Dowel pins in the holes brought it into perfect alignment during brazing. Nothing cracked.
  18. #14
    Dec 2016
    New York
    657
    9
    233
    I don't think so. I'm not all that worried about alignment. The problem is the base is too wide so the time i hack it up to get the proper side clearance, putting humpty-dumpty back together again will be a bit of a pia. Easier to just send it back rather than screw around with it.
  19. Likes michiganbuck liked this post
  20. #15
    Jan 2005
    The Netherlands
    6,456
    337
    1837
    Thats why I prefer to modify a steady that is on the low side for the intended lathe Just mill some flats on the underside and bolt on a subplate
    And if the total wide is about the same as original it even looks good
    Peter
  21. #16
    Jun 2009
    Rosamond, CA
    398
    181
    325
    Or just make one. It's not hard... For my Graziano SAG12, piece of 1.5 inch thick mystery aluminum I found in the shop (it cut like 6061.) Some half-inch bolts
    with bearing bronze caps pressed onto the ends. Works just fine...
    Bill
  22. Likes BT Fabrication liked this post
  23. #17
    Dec 2016
    New York
    657
    9
    233
    Quote Originally Posted by 310 Guy View Post
    Bill
    Nice job. That's a much better alternative than bodging up a nice steady
  24. Likes 310 Guy liked this post
  25. #18
    Mar 2005
    Maine
    1,457
    9
    607
    I posted a couple for sale a week or so back.
    Maybe they'll be closer to what you need.
    A couple of steadies and a follow rest for sale.
