Tiny Antique Flypress
Results 1 to 13 of 13
    Feb 2006
    Indiana
    12,790
    652
    3779
    Default Tiny Antique Flypress
    I saw this on eBay and thought it would be of enough interest to antique and miniature enthusiasts to post here.
    I think the frame casting and the logo look a bit modern, but the rest looks antique. I am puzzled as to age and whether it is a real press or an advertising object. I do not believe the pill story.
    ANTIQUE APOTHECARY MANUAL TABLET PILL SUPPOSITORY PRESS MOLD | eBay
    Larry
    Aug 2012
    California, Central Coast
    3,333
    2153
    1299
    He is asking $199, Text of the add:
    This is a beautiful antique cast iron with brass press. It appears to be extremely rare. One side of the press has a backwards R overlapping the letter G followed by "No. 2995". The other side is blank. It has a lovely L-shaped handle and helical geared feed.
    The device seems to work exactly as it should. When the L-shaped handle is turned clockwise the helical geared feed lowers and retracts when it is released.
    It is approximately 8 1/2 inches tall with a base of about 5" in length.
    Jan 2001
    Somerset, England
    342
    181
    98
    I have a similar one (somewhere)
    I understood they were used for setting press studs etc in leather goods, at least they work very well for that task. Had to make up several 'tools' for the various sizes of studs.
    Mark
    Jul 2007
    UNITED KINGDOM
    4,727
    2488
    2291
    I wanna see a close-up of the helical gears...
    Aug 2012
    3,333
    2153
    1299
    Quote Originally Posted by Mark Rand View Post
    The very end of the fast thread is barely visible if you look. The ebay pics are better to zoom in on. I am not sure how it is staying up? It should spin down. Old sticky oil maybe...
    Feb 2006
    Indiana
    12,790
    652
    3779
    Quote Originally Posted by Rob F. View Post
    To zoom in on a picture in PM, open the picture and then click on it. It will open in its own window. Now hold down the Ctrl key and tap the + key as many times as you want and the picture will enlarge with each tap. The - key will reduce. Eventually, it will run out of resolution, but the pictures I posted from the eBay listing are very good, so you can see the tops of the spirals. Hold Ctrl and press the top row zero key to restore to normal size. Use the back arrow to return to the PM post.
    Larry
  7. Likes Rob F. liked this post
    Sep 2010
    moscow,ohio
    5,905
    579
    1889
    button press??
  9. #8
    Jul 2010
    Virginia, USA
    3,419
    86
    616
    Heh, yes- it is a button press, used for overall and jeans snaps and the like.
    allan
  10. #9
    Feb 2006
    Indiana
    12,790
    652
    3779
    I searched button press and just got lever and plier-type devices. But then I searched antique button press and found several pictures of the fly press type. Thanks for the answer. I was pretty sure the apothecary story was bogus.
    Three Antique Button Press Devices - Catawiki
    I started doing leather work in 1955 and bought snap fasteners and the tools for setting them from the local Tandy Leather Co. store. I still have them. My tools are just punches that you hit with a hammer. I have some old eyelets and a plier-type setter. I had never seen one of these little screw-type presses.
    Larry
  11. Likes Lester Bowman, Rob F., Markusfu liked this post
  12. #10
    Nov 2014
    Florida
    3,434
    1480
    1621
    Quote Originally Posted by L Vanice View Post
    Larry
    You can also hold the ctrl key and zoom using the mouse wheel. Also, ctrl0 (zero) will reset to 100%.
  13. #11
    Sep 2010
    moscow,ohio
    5,905
    579
    1889
    Can't find anything on "RG"..
  14. #12
    Oct 2012
    312
    123
    140
    seems like it would be more ergonomical if the handle curved up instead of down. Unless it's meant to save space in storage.
  15. #13
    Oct 2009
    Louisville, KY, USA
    926
    213
    204
    Most fly presses have a multi-start thread, the action of pressing a button or rivet probably requires less than 90° of handle movement.
