Tool post conversion
Results 1 to 6 of 6
    Jan 2021
    7
    Default Tool post conversion
    I bought an early Harrison 13 lathe. I need toupgrade the tool post. What should I measure or be looking for? This is primarily a hobby lathe for me
    Mar 2020
    CANADA
    Quebec
    303
    507
    187
    Height from the top of your compound to the center of the spindle or tailstock.
    Feb 2016
    2,173
    1544
    940
    As mentioned, you first need to know height from top of compound rest to center line of spindle.
    Now knowing that number, lets assume Aloris style qctp. They are sized axa, bxa, cxa etc. I think you'll want either bxa or cxa. No need to guess. Go to Aloris website. Google both bxa and cxa for their site. Look the dimensions of tp. Now google bxa-1, and cxa-1. The tool holders. Look at dimension of tool holder, and figure its mounting on tool post.
    You want adjustment range to go above and below that centerline number you measured.
  4. Likes Scottl liked this post
    Jul 2004
    Houston, TX USA
    32,343
    CXA was perfect on my ( actual swing 14 1/2" ) 12" Pratt & Whitney. If the Harrison is nearer 13" actual swing maybe a BXA would be a better fit
    Feb 2006
    Indiana
    14,008
    811
    4749
    Quote Originally Posted by texasgunsmith View Post
    You also need to know/decide what size tool bits you will use. I use a QCTP that can hold 3/4" tool bits, but I use 1/2" tool bits, so I need a riser under my tool post.
    You subtract the tool bit height from the compound to lathe center. Then the balance is the maximum thickness of the support flange under the tool bit on the toolholder.
    Larry
    Apr 2009
    NW Florida
    382
    26
    128
    I use a CXA on my Clausing Colchester round head 13 x 36.
