Twin Tool Mfg Co drill press hand crank (Twin Tool Manufacturing Company)
Results 1 to 6 of 6
    Jun 2019
    CANADA
    Saskatchewan
    5
    Default Twin Tool Mfg Co drill press hand crank (Twin Tool Manufacturing Company)
    Hand crank manual drill press or similar tool. Twin Tool Manufacturing Company. Is it a drill press? Will it auto feed or would I crank and feed? It has a ?1/2”? straight bore with set screw. What’s your “Best” way to convert to a Jacobs chuck?
    My search finds post drills on PM but this is different.
    Thanks in advance for helpful advice.
    And how do I post pics?
    Mar 2007
    On Elk Mountain, West Virginia, USA
    2,075
    885
    706
    To post pic, click "Go Advanced" below the typing box.
    To put a Jacobs chuck on your drill, you could make an arbor with 1/2" straight shank or turn down a Morse taper one. My favorite way is to take the spindle out, cut off the 1/2" socket and turn down and thread the end to something like 5/8-16 for a threaded-back chuck. Then you know it will run true.
  3. Likes Eww liked this post
    Jun 2019
    CANADA
    Saskatchewan
    5
    So it turns out what I bought is called a "Cole drill." It came with the v-shaped work support but not the large vise.
    Drilling Holes, Cole Drill, Ratchet Drill
    colevise
    Cole drill
    A 1/2" bolt with the head cut off, into a spare chuck. MagneticAnomaly's first suggestion got me there... although I'm sure this doesn't run terribly true, it's drilling well enough for my needs.
    Thanks!
    Dec 2009
    Dearborn, Michigan
    1,248
    81
    204
    That is pretty cool. I had a project where that would have been handy.
    Mar 2004
    Princeton, NJ USA
    1,811
    1461
    420
    Those things work great, I should have kept mine.
    Jun 2019
    CANADA
    Saskatchewan
    5
    I'm using it where a well-equipped fabricator might use a magdrill. It's kind of fun : - )
  8. Likes sandiapaul liked this post
