For the OP (cyware)-
The critical components with these toolmakers microscopes are the optics. If it was packaged like the OMT version there should be several objective lens assemblies with varying magnifications and at least four different eyepiece/ocular assemblies that measure different things. These should vary from a simple eyepiece with graduations to radius measuring and angle measuring tools. These typically have a separate illumination source to read a very precise optical vernier scale. Along with these will be a power supply for all the illumination sources. You can see a power supply in the photo that Asquith posted.
There will probably be a number of other accessories that add to the functionality. A hood that allows you to use it as a comparator to an accurate scaled drawing like a Shadowgraph, centres for use with shafts and for measuring screw thread profiles, various vee blocks, and a small set of slip gauges for moving the table beyond the range of the X and Y micrometers. You could fabricate or buy replacements for these if you need them, but probably not for the optical asemblies.
I would ask the seller whether they still have any of these for sale. As a milling machine I would say that it might be acceptable for cutting plastics. With the optical parts it could be really useful for the right kind of work.
