Unknown vintage lathe identification
Likes Likes:  0
Results 1 to 6 of 6
    Jun 2021
    SPAIN
    Default Unknown vintage lathe identification
    Hello everyone!
    I've just bought a very old precision lathe and im getting crazy trying to identify at least the manufacturer or the year. It has no numbers or letters except "LM" behind the 4" plate. I hope anyone can help me a bit and send me in the right direction because i need to buy, adapt or build the countershaft and the backgear... thank you in advance!
    Attached Thumbnails Attached Thumbnails img_1352.jpg   img_1068.jpg   img_1342.jpg   img_1341.jpg   img_1339.jpg
    Dec 2020
    Oklahoma
    99
    49
    33
    I think serial numbers are frequently stamped on the ways down at the tailstock end.... at least on my Hendey that is where they are.
    Sent from my SM-N960U using Tapatalk
    Feb 2006
    Indiana
    14,004
    810
    4747
    Here is a very valuable source of information on many makes of old and new lathes. Once you have a maker name, you can look it up here. You can hope that a reader will recognize your lathe and make it easy.
    If you want to take the time, you can open each promising maker name (the country is listed with the names) and look for pictures that match your machine. To start, it is helpful to remove some bolts and determine whether the threads and head dimensions match USA, UK or European metric standards.
    Machine Tool Archive
    Larry
    Apr 2013
    Damascus, MD
    1,706
    5020
    973
    With flat ways and gap, it looks more like British or European.
    I second the suggestion of checking the threads. however, if they are imperial rather than metric, it doesn't excludes that it was made on the Continent.
    Paolo
    Feb 2007
    Ontario, Canada
    164
    321
    24
    Very nice lathe! You might measure the lathe bed up and compare it to the English Myford or the earlier Drummond lathe. Some versions have a similar flat way bed design and you may be able to fit or modify very common accessories to your lathe.
    Jun 2021
    SPAIN
    Thank you for your replies. I need to spend some time comparing the threats in detail. But i am quite sure they are english threats. For example the plate, has 4 inches diameter and the plate threat is a 3/16" 8 TPI i guess. I send attached some more photos.
    I think its not so difficult to find a countershaft that could fit my lathe, maybe a South Bend 9inch or a similar one, but what should i do to find the right gear set? because i only have the 20(x2), 25, 50 and 60 gears. They are half an inch width and the 50-60 are 65 and 77mm respectively and teeth are 3,5mm deep.img_1332.jpg
    I found an ad of a small lathe chuck manufactured by "L.M. Co." (see photo attached) and I wonder if this could be the same manufacturer im looking for because of the LM monogram in my plate. Does any one know something about this company? i didnt find useful information.
    Thank you for your help!
    Attached Thumbnails Attached Thumbnails img_1292.jpg   img_1352.jpg   img_1345.jpg   img_1379.jpg
