Unusual height gage
Results 1 to 9 of 9
    Aug 2013
    Worcester County, Massachusetts
    886
    313
    108
    Default Unusual height gage
    I picked this up in a lot of tools I bought last week. I took it because I'd never seen one like it, and I'm a sucker for old junk.
    Says it was made by the American standard Co. Of Plantsville, Connecticut
    Appears the company was known for metal stamping, and some tool making.
    But I can't find Ny machinist tools by them.
    The wheel in the base appears like it should be a fine adjustment knob, but it only turns a little each way then stops, and the height doesn't appear to change.
    Anybody ever see one like this? Figured I'd as here, where all the fans of old iron & tools hang out.
    Steve W.
    Sent from my SM-J737P using Tapatalk
  2. Likes rustytool liked this post
  3. #2
    Jan 2007
    Norfolk, UK
    18,930
    14437
    14500
    I suspect it's some sort of mounting for a dial test indicator to be used against a surface plate as height check etc etc
    Virginia
    27,630
    7561
    8604
    Quote Originally Posted by Limy Sami View Post
    Spot-on. An indicator holder is exactly what it is, and yes, large plate or small, large parts or small.
    Uncommon only because... "mostly" we'd use readily-available clamps to attach a DI to our more common VERNIER height-gages, take advantage of the better features of each component.
    Which still works a right treat, FWIW-not-much, "batteries included" or ever needed not.
    Aug 2013
    886
    313
    108
    Well, I don't imagine itll see much use here. As you point out, plenty of better options at hand. But I still think it's an interesting early piece.
    Steve.
    Feb 2005
    Owl's Head, Maine
    2,253
    365
    608
    Has its uses as a stand on a surface plate, more for comparisons or zero setting than as a conventional "height gauge". Yes, that horizontally oriented bottom wheel is a fine adjustment, and if yours turns only a bit each way and doesn't change heights it is gunked up or rusted or otherwise damaged.
    -Marty-
  7. Likes TDegenhart, AD Design, Leg17 liked this post
  8. #6
    Aug 2013
    886
    313
    108
    Quote Originally Posted by Marty Feldman View Post
    -Marty-
    Bunked up sounds right. I was able to turn it more, but it wasn't easy, and as the post rose, I could see some crud on it. Bet it's been sitting for years.
    Steve.
  9. #7
    Aug 2013
    886
    313
    108
    Spent a little time on this tonight. I got it apart, cleaned off the gunk, and reassembled it. Now it works nicely. Didn't think there'd be a spring in there, but it makes sense. The spring keeps any freeplay from being an issue.
  10. Likes rustytool liked this post
  11. #8
    Jan 2005
    Rhode Island
    153
    46
    Until maybe 20 years ago there was an American Standard plant in eastern CT. Made toilet and other such bathroom fixtures I believe. I don't know if the area was known as Plantsville though. Never heard the area refered to by that name. I think it is known as Wauregan. Anyway this might have been used in their toolroom or made by them for use in their plant.
  12. #9
    Jul 2001
    North Carolina
    1,967
    178
    401
    Man, that thing is sooooo kool.
    It would look really nice on the surface plate in any shop.
    It has the old timey straight up/down adjustment knob.
    I always like those because of the sexy way the knob is let
    into the casting.
    --Doozer
