Just an astounding machine.
I notice that the front drive wheel set is running opposite of the rear set.
When the crank is up on the front, it is down on the rears.
I wondered if this is coordinated thru valving, perhaps for balance?
I wondered if they were just random and if one set were to slip and if they would go out of sync.
It's hard to tell when they show the other side, because it is really roaring, but it looks there that they are synced the same up and up, down and down.
So I assume that the front and rear sets are independent, but then I wonder, are the axles solid or can right and left, of both front and rear, be adjusted for going around long curves, like a differential, or do they rely on slippage?
I haven't played with trains since I was six years old, but still fascinating!
Mike
