Mikey D
- Jan 4, 2006
- Good Ol Sunny Arizona
Howdy Folks,
I posted this in the Bridgeport forum and someone recomended it would be better served here. Pictures will be in the 2nd post.
I just purchased this mill and hope ya’ll can help me out with some information. The door on the base says:
Van Norman Duplex Milling Machine #2
Patents Nov. 3, 1895 and mar 9th, 1897
The head is a small Bridgeport with an old 110V ½ horse motor and the serial # is M10655
I’ve wanted a mill since I apprenticed in a shop in high school. I’m 45 and teach Auto Shop and finally was able to pick this up for my shop at school. Yes I used my own money as the district will not purchase one for the school but I think it’s worth it to show the kids (as none of them have graduated knowing what a mill or lathe is) and to expand our shop capabilities.
The machine has a motorized traverse (x and y) and as you can see by the pictures, the top is missing something. Buy guess and by golly I figure this had two heads on it (hence the duplex). It almost seems like there was a horizontal spindle where the Bridgeport head is now and maybe a vertical spindle next to it (on the left), the missing head could pivot up and down (from the slots in the casting). The current Bridgeport head is mounted on a ram that can move in and out (not unusual) but the ram is mounted on another way that can also move in and out.
All 3 axis are movable but are sticky (not sticky actually, just hard to crank) and I’d like to make it work like it should. We have begun cleaning it up (mineral spirits & steel wool) and putting a fresh coat of oil on the cleaned ways to prevent rust (My auto shop has swamp coolers that ruin cast iron in minutes!).
As I teach Automotives and have a machining background I’m pretty mechanically adept but have never disassembled something like this before. Any hints or suggestions are very welcome and would be appreciated.
Questions like:
Should I disassemble this or can it be cleaned up assembled?
What was the original configuration of this mill and do you have any picts of what it was?
The patent dates are in the late 1890’s but is there a way to tell when this was actually made?
… are all ringing around my head.
Don’t be sparing with the info, I’ll not take offense if you figure I know nothing about this rig. Thanks in advance!
Mike
Questions like:
Mike
