...Video...No CNC for these Cranks...
I saw that video, you just made me watch it to end, Thanks. Amazing! like looking back in time except it is color and the guys are wearing flip flops. What I wonder is how many hours labor for each crank and how much money do the get for each? Are these all sold to a manufacture for new engines or they aftermarket replacement parts?
How lucky we all have it!
There's a lot of precise work that can be done with very simple fixtures and guides. A lot of those same operations would be relegated to 4 and 5 axis CNC machines in the name of saving a minute or two of run time. Of course there's a big difference in 10 guys making 50 pieces in an 8 hour day and 1 guy making a piece an hour, non stop 24/7.
Got to respect the skill of the machinist building these, i do believe the vidio left out some of the manufacture like straightening of the crank several time during machining ops, bad enough grinding one that has been repaired by welding as stress is released the crank bends. No checks for flaws or bad castings but they are cheap to buy. Their rough centering indicators are ideal though, if you crash it just bend it back [emoji16]
Looks like a scene out of a Bull Of the Woods cartoon, except cleaner, and better lit!
LULZ! at the guy at 23:30, who has obviously figured out that a bedsheet may be comfortable, but with enough sparks, it's worth wearing some gear!
I had watched this youtube a few days previous to it being posted here. I noticed that the machine tools used were an interesting mix. One lathe is a geared head, and may be of English manufacture. The other lathes are of the same 'vee belt' headstock design as the Yogi lathe discussed in another thread on this 'board. The vee belt headstock lathes are likely locally manufactured. A Cincinnati horizontal milling machine is used to mill the keyways in the crankshafts. Another oddity was the use of small 3-jaw lathe chucks on the drill presses.
The crankshafts are likely being made as replacements for diesel engines in tractors. Could be a replacement for the crankshaft in a number of tractor engines. Massey-Ferguson tractors are prevailent in Pakistan and India, maybe produced under license. There are Mahindra (Indian made) tractors and a number of other manufacturers which we, in the USA, probably never heard of.
Watching youtubes of rural life in India and Pakistan, it is more common than not to see trucks and tractors grossly overloaded. Mechanics carry out repairs any way they can, often working with improvised tools on the bare ground. It is rare to see a torque wrench in use, and even ratchet wrenches seem to be in short supply. I am sure the crankshafts made in this youtube are going into tractor engines which will be run hard, not maintained remotely per manufacturers' recommendations, and run under overload quite often. Little wonder that shop was producing large numbers of replacement crankshafts.
Gasoline engines in automobiles and light equipment often use nodular cast iron crankshafts. I was surprised to see the crankshafts in this youtube were some kind of cast iron as well. This was obvious not only from the appearance of the raw castings, but the chips when the castings were machined. From what I have seen of Indian and Pakistani foundries, getting a consistent grade of nodular iron for crankshafts might be something of a grab-bag. Many of the foundries use coke-fired cupola furnaces, and some use induction furnaces to melt the iron. Youtubes of the foundries show a kind of laid-back way of doing things, with no precise weighing out of what gets charged into a melt. Scrap such as sprues and gates from previous runs of castings, along with scrap in the form of busted up junk castings and scrap steel, along with some 'pigs' (probably excess iron from previous melts) make up the charges. Maybe the foundries pouring diesel engine crankshafts are more exacting in their control of what goes into a melt.
The crankshafts are being made by manual machining, using micrometers and vernier calipers. Given the type of machine tools used and the type of measuring instruments used, the accuracy of the crankshafts produced likely is nowhere near what crankshafts produced by the diesel engine OEM would be. The metallurgy of the castings and the degree of accuracy of the machining raise a few questions. Namely: how well do these crankshafts hold up in service ? Chances are, like so much of what I've seen on youtubes about Indian and Pakistani mechanics and locally made machinery, the crankshafts and bearing inserts are setup so clearances are on the looser end of things to start with. Like so much else in that part of the world, the people work with what they have and know. Running an engine hard and with minimal maintenance is common. Changing crankshafts with a shorter service life is an expectable part of operating tractors in India or Pakistan. The main thing is the people find ways to make what they need and keep their machinery and equipment running.
As Joe M. said Massey Ferguson tractors are popular there. They still make new tranny gears for 1960's MF tractors there. The three cylinder crankshaft is for probably for a 152 Perkins diesel, also used in the Massey Ferguson tractors.
I recently needed transmission parts for my 1960's MF tractor and had to order from India. Also popular there.
No U.S. source for some of those parts.
Yeah, I have a FE-35 Diesel Deluxe from 1958, that predates the Massey Ferguson buying of Perkins, mine has a 4 cylinder Standard Engine Co. Diesel, and I have found out that they are still making pretty much the same 1950's tractors over there, so parts are available! Yay.
Stuff like rebuild kits, or complete new parts, are pretty available, and not too expensive., Mainly though, you can still get a lot of the replacement body parts that you just couldn't consider, if you were stuck dealing with the current iteration of MF.
Nice! At 39:45, they are crating them up and both Belarus and MF-240 markings are visible on the crates! Dunno if they are the same crank, but...
Seems like a happy shop in general, apparently some cross-training also. I wonder what turnover and promotion looks like there- must be quite a few competing shops.
An awful lot of very good crankshafts made in the USA before these things called cncs came about.
Seems to me, most of the machining has to be 'close enough', while the final grind to dimension needs to be pretty much 'bang on!'
I won't suggest that the tolerances at the end, are within the capability of a guy with a wooden ruler, but a lot of the machining ops may well have been.
Many of the measurements were done with calipers, in the roughing work. I saw at least one instance where a guy used a metal scale to check something.
Once it got to the grinder, I saw mics and indicators.
The crank grinder is using a swing down Arnold gage....at 35:09
The lathe tools looked either hss or carbide tipped and not indexabele. This reminded me of a job I did in Egypt some time ago. A german engineer needed the use of a lathe for the repair of a high pressure pump we were using. After showing my driver a picture of a lathe we were taken to a local shop where, after some negotiating, we were allowed to use the lathe. It was Bulgarian and probably made in the 50’s somewhere. Its regular machinist had never seen the indexable tool the engineer brought with him, but gladly accepted it as payment for the use of the lathe.
Saw the gage being used, did not know it's name. That was the swing down long shank indicator he used to check his final dimension, I think. No?
That grinder looked an awful lot like the one that I stood and watched do my crank in a shop in Moose Jaw a few (dozen) years back.
I think a lot of guys forget that there is a lot out there that does not actually need micron tolerances to work well.
