Anyone ID the machine?
Personally, I'm surprised they have what appears to be proper soluble-oil coolant. You'd think they'd just have old engine oil, or used goat milk or something.
Doc.
It looks like an old " Ward " No2 or No3. The rugby ball shaped end caps on the side of the headstock are typical of the smaller " Ward " capstan lathes. Plus the Fast/Slow and Forward/Reverse levers mounted on top of the headstock.
Regards Tyrone.
Yup I'm going with a No 2, the smaller holes in the hex turret (from memory the No3's are 1.5'' - Nos2's 1'') it is also fitted with the Ward collet chuck which does not use a draw tube so leaves the full spindle bore available.
Spindle bores - No2 1.25 std, & 1.5 big bore, No3 1.5 std, & 2'' big bore
On the Ward the reversing and speed changes was all done with clutches, ...........whereas most (if not all??) Herberts were at least part electrical.
..."Another series of youtubes I've been watching is "The Pakistani Truck Channel". This is a series of youtubes taken in Pakistani heavy truck repair shops.
...Joe...I've been watching the Pakistani Truck Repair channel too...fascinating...
It was on a lathe just like this one that I had my first and only semi serious lathe accident. When I was a young apprentice I was making some fittings with 5/8" Whit tapped blind holes in the end. Just as the lathe was coming to a stop I attempted to flick a loose turning out of the tapped hole with my finger. My left index finger was screwed into the hole pretty quickly ! Before I knew what I was doing I'd thrown the lever into reverse and unscrewed my finger. The last joint was pretty messed up and I've never regained full use of it.
I learnt my lesson with machinery very early in life.
Regards Tyrone.
Notice
