I'm cleaning up above lathe and need some advice. I'm trying to disassemble the feed clutch. I have made a pin spanner and have removed the back side nut. Does the front clutch screw, #32, unscrew from the clutch gear, #45, right hand threads?
Trying to figure out how to hold the clutch shaft from turning while unscrewing the clutch screw took me a while, but I have found a way. On another lathe, I put the end of the clutch shaft in a collet with the headstock in it's lowest gear. Then advanced a drill chuck to keep the spanner square while not letting it back out. This is a solid setup. I have pulled on the spanner as hard as I dared and nothing has happened. Before I break anything, am I on the right track? Is #32 threaded on to #45? It's hard to tell from the drawing.
I can pull harder and something is going to give, I just want it to be the threads and not something else.
