Walker turner drill press question
Results 1 to 12 of 12
    Dec 2018
    Michigan
    6
    Default Walker turner drill press question
    I’ve got an old walker turner drill press that has a broken pulley inside the cast cover on the drill. My question is can it be replaced and how do you drop the chuck down thru the machine to change it. Thanks in advance.
    Jan 2011
    BFE Nevada/San Marcos Tx
    1,316
    1274
    718
    How broken is pulley? Just a little piece gone, you probably can live with, major chunks gone replace, but it ain't cheap. IIRC you remove quill return spring, quill handle, and quill drops out the bottom. Depending on model, iirc, there are different ways the top pulley is removed, show us what you have.
  3. Likes J. Mcglothlin liked this post
    Dec 2018
    Michigan
    6
    The largest ring on the pulley has a large chunk out of it. I tried running it but it’s too rough. Not sure how to post a picture on this thread.
    Dec 2005
    Waukesha, WI
    1,761
    413
    562
    It might depend on what model you have but my Walker Turner you do not need to remove the quill or the spindle. The top pulley is supported on two bearings that ride in a bearing housing that bolts to the very top of the guard. Remove three socket head cap screws and this pulls out. I can take another look at my machine tonight. Post pics it will help with our memory.
  6. Likes J. Mcglothlin liked this post
  7. #5
    Jan 2011
    1,316
    1274
    718
    Take pics, get them into your pic files, use "Go Advanced" to reply. Below text portion of page use the "manage attachments" button, find your pics and upload.
  8. Likes J. Mcglothlin liked this post
  9. #6
    Dec 2018
    Michigan
    6
    Here’s a couple pictures of the problem
    Attached Thumbnails Attached Thumbnails bf988574-f453-4c72-a237-1f4d5f248fab.jpg   86b8b23a-9085-402f-941c-f8fb7427bb1a.jpg
  10. #7
    Jan 2011
    1,316
    1274
    718
    I'm pretty sure you have to drop quill, then loosen bolts around the top bearing (see 1 bolt in first pic left edge of pic), if your lucky that bearing will lift out easily, if not, I typically use a bearing separator to grab that groove and tap it out. I seem to remember there is someone supplying parts for WT, but cannot remember who, other source would be ebay for a used unit. I know I contemplated replacing a pulley some years ago, cannot remember if it could be done with a new off the shelf pulley, would need custom bore, then use the old (or make new) brass spline pieces. I know I looked at that route, cannot remember if it was possible.
  11. #8
    Oct 2008
    Central Ohio, USA
    1,943
    828
    556
    The bad news is I think this is a 700 series drill which dates prior to WWII. Much harder to find parts for than the 900 drills.
    Quill assembly can be removed from below once the stop is removed. I would NOT remove the pinion and handle so you don't have to touch the quill return spring. Then you remove the two screws at the top and the top bearing can be removed. This should allow you to remove the pulley assembly.
  12. #9
    Aug 2003
    port allen, louisiana usa
    1,752
    482
    409
    I have a dp like that.. I wound up replacing the whole pulley with a cast iron one as the one I had was totally crapped out.. The bearing in it is almost impossible to find ...Ramsay 1:
  13. #10
    Dec 2018
    Michigan
    6
    Mike....I’m not sure what yr this machine is. The badge on the front of the drill says:
    Walker Turner Company
    “The Driver”
    Power Tools
    GKF
    Ball bearing equiped
  14. #11
    Jan 2011
    1,316
    1274
    718
    I think VintageMachinery.org has some literature on the WT drills and shows differences. I also seem to recall seeing model# cast into head/table/base on some models, but not all iirc. I have 2 in my shop, and have refurbed a few others, but its been awhile. The pulley bearings are no longer available, seem to recall there is a bearing available a few thou undersize that locktited into place does work, think I read that here or on another forum.
  15. #12
    Aug 2003
    1,752
    482
    409
    Some years ago I changed the bearings in my WT drill press along with the pulley on the spindle.. I used three cast iron step pulleys and made an idler in the middle so that I could get more speed range ....I used a motor off of one of the "unmentionable" lathes that I had on hand as it was very old and really fit nicely...
    There was a guy on Ebay who was selling the spindle pulley bearing (the one with an extended inner race on one side) so I was lucky there...
    Mine has served me well over the years.. It is a table model and I have it on a stand with drawers underneath for storing drill press related items.. So now I have four drill presses... LOL always good to have a spare...Ramsay 1
  16. Likes GusBros liked this post
