Hi all, I'm a blacksmith in Milwaukee, WI. I have an addiction to older mechanical power hammers. I love to get them fixed up and restored and forging hot steel again.
Many (most) power hammers typically run at slower speeds. In the past to reduce speed I have done a few different solutions.
1) made jack shafts utilizing different pulley diameters to obtain the correct speed.
2) used VFD's to reduce motor speed.
3) used gearboxes to reduce speed.
Those three things usually work, but sometimes circumstances (or space) don't allow for a jackshaft, or an additional gearbox. And sometimes to keep things more "original" a VFD just doesn't play the part well.
So... I'm in the market for some low RPM (induction) motors. 3hp up to 10hp or even a bit bigger. I know they are tough to find, which is why I'm asking around here. I have 3 phase, so no problem there. I have seen them in speeds between 800 and 900 rpm. That general speed is what I'm after.
Thank you for your time,
Aaron
Aaron
