Warner & Swasey forklift
Andy FitzGibbon
Sep 5, 2005
Elkins WV
This popped up on Facebook marketplace. Haven't seen one before. Anybody know what the "Duplex Division" of W&S was?
Sent from my SM-G950U using Tapatalk
Seeing the Warner & Swasey name on the forklift reminds me of Warner & Swasey's developing and builing the "Gradall" excavator. I believe the first generation Gradalls were wholly a product of Warner & Swasey (or some division thereof). W & S had to have had a division setup to build construction or heavy equipment using welded construction and industrial hydraulics. This was quite a stretch from building turret lathes, and would require an entirely different type of physical plant. Just as W & S was diversifying by getting into the building of the Gradall, it would stand to reason they diversified the products in the division building the Gradall to include forklifts. As a very simplistic viewpoint: a division building forklifts as well as Gradalls would likely sell a lot more heavy-duty all terrain forklifts than Gradalls, and forklift sales might have been planned to keep the division afloat.
I think the Gradall was one of the first hydraulic excavators. For its time, it was quite a step up from cable operated excavators. Gradalls are still manufactured today, though the connection to Warner & Swasey was severed a long time ago. The design of the Gradall makes it an ideal machine for excavating trenching, as well as grading shoulders of roads and similar work. On my first job out of engineering school, in 1972, we had a W & S Gradall on the job. We were using it to dig a few miles of trenching for underground fuel oil and fire protection piping. As I recall, the Gradall had a large V-8 gasoline engine on the carrier, and a Detroit Diesel on the actual excavator. I remember marvelling at the fact the Gradall operator could move the carrier along from the "upstairs" cab while working. Years later, on our local tourist railroad, we got hold of a later Gradall with 'high rail' gear for running on railroad tracks. This Gradall was setup with a shorter boom and intended for trackwork such as maintaining embankments, ballasting, and ditching. Same setup: gasoline engine 'downstairs', Detroit diesel "upstairs".
As a kid, I remember seeing an advertisement for Warner & Swasey's turret lathes in some everyday magazine (maybe 'Time' or "Newsweek") in which they described how a W & S turret lathe took something like 90 lbs of metal off a casting to machine it in some very short time. I also recall seeing ads from after WWII in which the machine tool manufacturers were trying to diversify since the demand for large numbers of machine tools had dried up. I know Lodge & Shipley tried building a small one-wheel lawn tractor, and some of the other machine tool builders dabbled in other product lines. W & S was likely in this same boat with the building of Gradalls and forklifts. I suspect that W &S sold a lot more Gradalls than forklifts, or at least the Gradalls are a lot more visible.
Gradalls were once favourites of the railways here ,as they could easily cut a batter to grade with an incompetent operator.....They used to sell cheap too,as no one had much of a use for them...The big catch was for an excavator they could only work on hard ground ,and getting 25tons bogged wasnt to be contemplated......Gradalls also came in a tracked version ,using IIRC ,an Insley lower works .
I recall reading in the book "the rise & demise of WarnerSwasey" that W&S was flush with cash
and started buying up un-related business's.
Gradall
Duplex
Badger
Along with related (to machining) business's
S-P chuck
Manchester (cut off tools)
The gradal....I worked at a garage, where the owner saw the very first one, a prototype.
IIRC it was just after WW2, and the machine owner/builder was demonstrating it nearby, it needing some repairs, came around to the shop.
The garage owner said the hydraulics was the problem, the main cylinder was built like for an engine, with steel compression rings for sealing.
The lug nuts on the drive wheels gave it away to me, I knew I have seen one like that before. Last summer a guy was trying to sell me one. It’s has a Ford diesel tractor running gear under it.
Sent from my iPad using Tapatalk
I hope you bought it and blew up the tyres before they get cracks in the rubber......One of these would be a great junk collectors forklift.......and plenty of grip for the muddy back yard.
Because of the big drive wheels ,the load centre has to be well out from the axle ,and so capacity is generally half what you would expect from the size.....Still ,these factory built tractor forklifts are in great demand for their versatility.
