ivan schafeldt
- Jan 11, 2019
i have this spindle milling slide and cant find what kind of watchmekers lathe it fits, i think ive exhausted googles images and can find plenty almost identical objet d'art but not exactly...
every other milling slide appears to have a flat base and hole for a mounting bolt but this one has a slotted chamfered slide mounting and no visible means to lock it into place, im presuming it somehow slots onto a cross slide, it looks similar to lorch attachments but as i said all of them have flat bases and a hole
im hoping beyond hope there is a wizened font of all knowledge out there in forum world that can help me identify what it fits.
my measurements are a little off as i was raised on the metric dark side at the point imperial was being phased out and im trying to do this in old money
the spindle takes a 6mm.....1/4 inch collet about a 1/4 inch of thread at 30/32tpi ish so im figuring its not from the heavier 8mm selection (genius i know) of watchmakers lathes.
vertical slide length 3 1/4 inches, base depth just shy of 1 1/2 inches, width also shy of 1 1/2 inches the slide rail/chamfer is 1/16 short of an inch at te widest part.
i cant tell if the spindle knob is ivory or casein plastic so thats making it harder to tell an approximate age also
