"From what I read there was two methods of isolating rings on a party line. Other than changing the ring pattern"
The harmonic ringer wasn't used often. Typical party lines were done so you could get four sets on one line:
1) selective ringing from one side or the other of the line, to ground. This was mentioned above.
2) Polarized ringing, where DC was imposed on the AC ring voltage, either positive or negative polarity. The
ringer in the subscriber's set had a spring that could be put to press the clapper to one bell or the other. If
the polarizing dc pushed the clapper towards the bell it was already resting on, no sound would occur. The
set with the spring set in the other direction, would of course ring at that point.
This provided four easy possible multiplexed ringers on one twisted pair.
My neighbor to the south, had at one time been on a party line. He came to me one day and said, his phone
stopped working (ringing). I guess the central office finally got rid of the card he was on, that knew about
his particular ringer setup.
His phone was indeed set to ring from line to ground, and with the spring set on the ringer. I changed it out
and all was well. This incidently was a modern model 500 desk set, so that dated the party line.
The long/short pattern rings were used on bridging magneto service where one line went out into a sparsely
populated area, serving 10 or 20 subscribers. Often the set had the ring pattern listed on it. This kind of
service was still in use for a suprising amount of time. I recall such a party line that ran up the canyon
in arizona, as late as the early 60s.
At one point the telco installed a satalite link at the bottom of the canyon, and then everyone got their
own twisted pair. Now it's internet service all the way as well!
