What is allowable play in Babbitt bearings on a lathe spindle?
Likes Likes:  0
Results 1 to 7 of 7
    Dec 2019
    Illinois
    56
    10
    Default What is allowable play in Babbitt bearings on a lathe spindle?
    I have started working through the 1904 LeBlond I just acquired and observe .0015 play in the back bearing, and .0042 in the front. This seems extreme in the front, but what is acceptable?
    My only experience with poured Babbitt is in my 1929 Model A, and those bearings are smaller in diameter, better lubricated, and running at much higher speed (but run at .0015 clearance).
    Jul 2006
    Hillsboro, New Hampshire
    7,829
    1827
    5505
    Do some searching using the terms "babbitt spindle bearing clearance".
    Babbitt Bearings & Oil Film Thickness? is a place to start, the link at the end of that thread is excellent for real engineering information (but likely more than you need).
    I agree with you that the front clearance is too much.
    Aug 2012
    California, Central Coast
    3,930
    2215
    1552
    Does it have any shims under the bearing cap? If not, maybe a good idea to put some in for next time.
    Feb 2005
    1,196
    944
    1032
    Do you have a 48" lathe or a 14" lathe. I think .001" clearance for a 14" lathe is good and go up from there.
    Jul 2004
    Houston, TX USA
    30,226
    More important to me...
    Turns freely by hand
    Does not heat much at all at top speed
    I guess that equates to as little as possible clearance
    It is after all a precision machine tool, not a wheelbarrow
    Dec 2019
    Illinois
    56
    10
    Too much engineering information? That must be some sort of oxymoron!
    I have done some design of hydrostatic and hydrodynamic bearings, but at the low rpm and low flow of oil in this spindle I cannot count on the generation of a proper oil wedge.
    .0005" per in. of shaft diameter sounds about right. I will pull the bearing caps and see what I have... Perhaps I get lucky and the bearing is split and shimmed, and I can just adjust the shim stack.
    And it is a 17" lathe with a 3" shaft. So scaling from the 14" lathe gets me close to the .0015" resulting from the .0005" per inch guide.
    Mar 2005
    Kansas
    7,614
    440
    3530
    Are you having problems with the quality of work the lathe is producing? If its not broke don't fix it.
