Boringgeoff
- May 12, 2019
Hi all,
Two tools here which I think both do the same job. The brace, unbranded, is a foot long and has a 3 1/2" sweep. The socket on the business end is 1/2" diameter and the central hole is 1/4" and the prongs(?) 1/8" wide and extend about 5/32". I originally thought it may be a valve grinding tool or a split nut wrench but now unsure, a friend thinks it might be for priming an oil pump.
The other fits in a brace and looks pretty well the same as the first, slightly larger 3/4" wide and 5/16" aperture but the prong profiles are opposite to each other. This is marked "made In USA" on the body, on the tang "1 1/2 & 2" and what looks like the Cleveland Twist Drill Co diamond logo on the neck.
Any help identifying these two will be much appreciated.
Cheers,
Geoff.
Cheers,
Geoff.
