Wmw bt12/1 manual
Likes Likes:  0
Results 1 to 3 of 3
    Nov 2019
    NETHERLANDS
    Default Wmw bt12/1 manual
    Hello,
    Im new her and hope im posting in the right section of the forums cause i need some help.
    Im searching for a service manual for a heckert wmw bt12/1 geared drillpress
    Or atleast some info on how to remove the quill spring and drum.
    Got the tension of the spring but to remove the drum where the spring is locate in the spring has to come out i think cause i can see 3 allan screws behind it but getting the spring out doesn't seem smart and i cant see me getting it ever back in.
    Cheers corn
    Nov 2019
    NETHERLANDS
    Here are some pictures located of the spring in question.
    Instagram post by corn • Nov 5, 2019 at 7:22pm UTC
    As you can see i already did get one allen out but cant seem to figure out a safe way to reach the other 2
    Nov 2019
    NETHERLANDS
    Well still havnt found a manual of sorts but managed to get the spring out safely.
    Took steel pipe od close to id of the spring housing and made a splitt in it and managed to get that around the spring when i tensioned it takeing the tension of the spring housing end be able to get it out.
    See the foto's also found out there is a grease channel in the quill lowering axle
    But that it never been greesed jeh luckly not much wear.
    Instagram post by corn • Nov 6, 2019 at 9:41pm UTC
