Worm gear lube?
Likes Likes:  0
Results 1 to 3 of 3
Thread: Worm gear lube?
    Jan 2020
    Maine
    18
    Default Worm gear lube?
    I知 working on cleaning up my Pratt and Whitney branch lathe. I知 starting to put the cross slide back together. I was wondering if way oil would be ok to use on the work gears. Or should I be looking for a different product. Any help would be appreciated
    Jul 2004
    Houston, TX USA
    30,482
    Worm gears?
    ? Isn't it just a steel screw passing through a Bronze nut?
    Way oil would be fine
    Or...do you have a radius cutting attachment instead of a cross slide?
    Jan 2020
    Maine
    18
    Quote Originally Posted by johnoder View Post
    Worm gears?
    Yes it is. Just not sure of the brass nut I can稚 see it. At first it reminded me of a automotive steering box worm gear. But. Now that I look at it it is a screw. It is a cross slide
