This doesn't have a lot to do with the basic question of this thread, but relates to the article John just posted. Back in the 1970's I worked on a project at NASA's Langley Research Center that used 10 miniature hydraulic actuators to operate 10 flaps covering the entire trailing edge of a 10' long swept wing wind tunnel model. It was related to active controls for aircraft that are routinely used these days, like gust load alleviation, etc. The actuators were made in one shop and the wing was machined to accept the actuators in another shop across the street. The 2 locating pins for each actuator had .0001" clearance intended to accurately locate everything. The shop in which the actuators were made was temperature controlled, and the mating holes were put into the wing on a huge, beautiful jig boring machine like in the picture in John's article, located in it's own room controlled to the same temperature as the other shop. The jig borer originally had the trays that used precision length rods to position the work, but had digital readouts added. When the final machining of the parts was completed, the actuators fit perfectly onto the wing. I was always impressed with the precision those two shops, machines, and skilled machinists could produce. So the article in John's post was no exaggeration, and in fact twice the accuracy it quoted was routinely possible on the beautiful jig borer Langley had.
Irby
