Chris Rusch's 1930 Sedan Build / 4 days
Likes Likes:  0
Results 1 to 5 of 5
    Feb 2009
    Wisconsin
    112
    17
    Default Chris Rusch's 1930 Sedan Build / 4 days
    Dec 2000
    Coastal Dogpatch, SC, USA
    51,284
    2785
    5589
    That little drip rail press is interesting...didn't know about that one.
    Sep 2002
    Lawrenceville GA USA
    6,182
    718
    1322
    Quote Originally Posted by Milacron View Post
    you mean the shrinker/stretcher ? Or did I miss something else?
    Charles
    Dec 2000
    51,284
    2785
    5589
    Quote Originally Posted by CBlair View Post
    That little blue thing at 19:50 Cool video....a lot more "how to do it" info than a typical reality show.
    Sep 2002
    6,182
    718
    1322
    Yes that is a shrinker/stretcher and it is quite common and has been around a long time. Of course if you dont do any sheet metal work you wouldnt know about it. He is using it to shrink on side of the angle and that will cause it to curve on the flat. If you tried to do that with a roller or bender the angle would bend in two directions or twist. By changing the die set in the tool you can stretch metal and it will curve the other way.
    Charles
