Results 21 to 24 of 24
03-05-2015, 09:16 AM #21
06-08-2015, 02:59 PM #22
Baileigh is making a difference: Mississippi Industries for the Blind
Mississippi Industries for the Blind is a nonprofit manufacturing facility in Meridian, Mississippi who employs close to 90 employees who are blind.
Since 1939, this fully capable, state of the art facility has provided fabrication and assembly services for the Department of Defense, United States Post Office and for numerous Military and Government contracts.
From metal fabrication and product assembly, to call center support and document imaging and destruction, MIB prides themselves with some of the best employees money can buy. With an incredible sense of pride not often found in a traditional factory setting.
Here we have manufacturer Scott Carmen who is totally blind, using the RDB-250 tube and pipe bender to manufacture thousands of the solid rod tow bars that are utilized by the US Postal Service in their sorting facilities across the US.
Accurate to 1/10 of a degree, the RDB-250 outfitted with an indexing table can semi-automate your bending process by duplicating and repeating parts thousands of times in a row.
Please take a moment to check out a website that is truly making a difference
http://msblind.org
03-14-2018, 07:08 AM #23
Hello
Does any one know the manufacturer of pipe bending machines based fully or partially in the USA that sells under the brand "Monkey" or something of that sort ?
Best regards
07-31-2018, 11:46 AM #24
Good afternoon,
I am in the stainless steel tube bending business and I need to know what standards or specification are used in this field to determine the max amount of flattening or ovality the tube can have.
How do you measure a pinched tube at its bend radius to determine if it is in spec or not?
Thank you
08-10-2019, 12:21 AM #25
Hi, I have a small future project I need some advice on. What I need is some 3/4" or so tubing, steel or stainless that can be bent to 180 degrees with as tight of bends as possible. What would be my best bet for material and bending method? I only need to make a dozen or so bends. Any help will be appreciated. Thanks, Greg
