PL-1340e threading chart
Likes Likes:  0
Results 1 to 4 of 4
    May 2020
    Utah
    Default PL-1340e threading chart
    Iím wondering if anyone has had any luck with cutting a 13tpi thread on the PL-1340e. The chart on my machine doesnít have it listed and tech support says it wonít cut a 13 thread.
    Iím guessing that with the correct change gear it would probably work.
    As tech support has let me down Iím turning to you guys for some help. Does anyone know if there are different gears that would allow for more threading options.
    I could no the math but donít really want to if I donít t have to. 🧐
    Oct 2005
    western washington state
    3,697
    2641
    3865
    will this machine cut 14 tpi?
    May 2020
    Utah
    According to their chart it will do 15tpi and 12tpi. If I had the time I'd do the math and figure it out. I'm guessing there is a change gear out there that would make it work.
    Oct 2005
    3,697
    2641
    3865
    Default thread standards
    your machine will likely qualify as conforming to whitworth thread scheme introduced in 1841 by Joseph Whitworth
    Whitworth was son of protestant minister in England--avoidance of number 13 being well established in
    liturgical matters
    otoh--the US system of thread pitch introduced number 13 into the scheme via William Sellers in 1864-
    Sellers had no reluctance to use 13 for 1/2 diameter workpiece
    in the pics included is image of Whitworth thread table set forth in his 1841 paper --contemporary lathe builders
    often display Whitworth plates on machines--typically bench mounted--and thereby propagate a form of deciet
    denying the user a greater range 0f thread pitch choices
