Speed control on beader
Results 1 to 3 of 3
    Jan 2008
    Merced, Calif
    1,046
    1257
    219
    Default Speed control on beader
    Is their a way to add a speed control to work off a dial instead of the foot pedal ?
    Jul 2008
    Philadelphia
    1,942
    514
    445
    Default control change
    With out knowing the specifics i.e A/C D/C and operating voltage it is a guess. However I'm sure it is quite easy.
    If you send me the specs on the unit I will draw up a schematic for you. Don't know your level of electrical knowledge.
    Send me what data you have and we can go from there. If you can do it your self that is great, just follow the schematic. If your reticent about doing it, I would be happy to do it for parts costs I would very roughly say 45 to 60 dollars. Once I see what I am dealing with I should be able to give a more accurate estimate.
    Doug
    Sep 2004
    Louisville, KY
    1,159
    375
    392
    What's the reason? Special application, personal preference, or that crappy foot pedal with plastic gears that won't stay adjusted?
  4. Likes mllud22 liked this post
