1990's Bridgeport, CNC by Centroid with varidrive j head - Page 2
Likes Likes:  0
Page 2 of 2 FirstFirst 12
Results 21 to 23 of 23
  1. #21
    Mar 2019
    Delaware
    26
    It's home1990's Bridgeport, CNC by Centroid with varidrive  j head the iron is great. We'll see about the floppy not reading issue. I am going to try to get it running with a couple things. If not it looks like the drivers and motors are going to be all good for an acorn conversion. Life changing possibilities.
    Sent from my SM-A115A using Tapatalk
  2. #22
    Jan 2020
    Georgia
    13
    6
    pretty sure if you get a usb floppy emulator $30 and plug it into the floppy cable it will fix it or just get a used working floppy drive. then you can just copy your nc programs onto the usb stick and plug it in the front of the machine. only catch is that you have to format the usb sticks a bit weird so you have multiple 1.44mb drives so the control can see them. also gets fun splitting up larger programs into 1mb files if its a really large program.
    i would guess there are still some programs stored in the control so load them and see if they run just set your g54 z on part setup a long way from the spindle and dont put a tool in to avoid a crash. if your outside the machine limits centroid is pretty good at telling you when you push start to avoid a bump. if you can get it to do that and verify all the axis move as expected you could just use it once the floppy is fixed.
    yeah its old but what you planning to make on it? i have an acorn and an oak on my machines. one good thing about centroid is if you can work one of their controls (even an older one) you can pretty much work them all, the basic interface between them is fairly similar. The thing that gets better with the newer controls is usability, processing power for more complex code and features like touch screen, configuration wizards etc better code look ahead! BUT the basic underpinnings of the system are on similar building blocks.
  3. #23
    Mar 2019
    Delaware
    26
    I haven't had any luck with the floppy drive yet. Need to grab one. My brother has built me a laptop with a touch screen and he put linuxcnc on it as well. he got a cnc dedicated usb to db25 cable also. So one way or another were going to get this thing making noise this weekend. So I should be able to run the cnc4 motion controller with the linux cnc software right?
