new motor help
Results 1 to 19 of 19
Thread: new motor help
    Dec 2010
    northern steeler nation
    22
    Default new motor help
    says this needs a new motor, what is involved, does it have to be like the one on it now or any other motor, is this a j head, any other info please, dont know enough about them just by looking, thanks
    Mar 2011
    Geneva Illinois USA
    6,262
    2704
    2422
    The motors are special flange design, called a pancake. Yes, it is a J head, belt and pulley. Contact Jon at H&W Machinery, Home
    He can advise you and if you need a replacement motor can probably send you one.
    Also look at Ebay. Trouble with Ebay you are kind of shooting in the dark.
    Tom
  3. Likes HWElecRepair liked this post
    Dec 2010
    22
    thanks i will call tomorrow
    Mar 2009
    5,222
    97
    971
    It's not going to be a big deal. A pan head motor replacement would involve little work. Alternative is to get the existing motor to a shop and see how much a repair would cost. A motor with mount holes like the one in the upper left corner would require a simple aluminium adapter plate.
    motor case types - Google Search
    Dec 2013
    Fort Wayne, IN
    700
    763
    251
    I freaking hate the pancake motors. We have 2 replacements for the step pulley motors, one in 3ph and a single phase variant. I am linking them here.
    I will be on a service call this morning, so if you call, dont ask for me cause I wont be in the shop.
    3 Phase
    Single Phase
    Hope this helps.
    Jon
    H&W Machine Repair
    Mar 2011
    Geneva Illinois USA
    6,262
    2704
    2422
    Quote Originally Posted by HWElecRepair View Post
    3 Phase
    Single Phase
    Hope this helps.
    Jon
    H&W Machine Repair
    You guys are better than I thought. You can take a single phase motor and convert it to three phase with a few brackets?
    Three Phase Conversion Kit for 1 HP Bridgeport Motor
    Tom
  8. Likes HWElecRepair liked this post
  9. #7
    Mar 2009
    5,222
    97
    971
    The motor pulley housing should have a lever on the right side just behind the belt guard. That lever allows the motor to rotate to loosen the belt. It is missing.
    The is a lot of aluminium fins on the outside of the pan motor. Is that original?
  10. #8
    Virginia
    28,010
    7561
    8686
    Quote Originally Posted by TDegenhart View Post
    Tom
    LOL! One suspects that is a website editing need?
    BUT.. while a 3-P motor needs an RPC, VFD, or P-P to run off 1-P, it is true that a single-phase motor only needs two "hots" off a 3-P source, so yes indeed:
    Brackets and pulley bore & broach and run she will do!
    Lathe will appreciate 3-P smooth. Single-point tool, CONTINUOUS in the cut.
    Mill? BFD. Most cutters have flutes or such. "Continuous" isn't there to begin with. Tool marks will be, regardless. Only real benny to 3-P is simpler and faster reversing.
  11. #9
    Dec 2013
    Fort Wayne, IN
    700
    763
    251
    Tom
    Had to re-read both of these. At first I was really confused about what was going on. No one has ever pointed that out.
    Thanks for the heads up
    Jon
  12. #10
    Virginia
    28,010
    7561
    8686
    Not really. There was only one.
    That was the problem!
  13. Likes HWElecRepair liked this post
  14. #11
    Jul 2009
    UK
    113
    53
    14
    When I was faced with this problem I took a normal, flange mounting metric framed 1.5 HP motor and extended the shaft. It fitted inside the old pancake flange and worked perfectly with a VFD.
    Charles
  15. #12
    Virginia
    28,010
    7561
    8686
    Quote Originally Posted by Charles P View Post
    Charles
    If that's a Brooke-Crompton, "normal" is a bit of a stretch!
  16. #13
    Jul 2009
    UK
    113
    53
    14
    Wasn't a Brook Crompton but it was 90 frame sized B5 flange mounting metric motor. Standard kit made around the world and I'm sure that Brook Crompton make them in that size too.
    The trick was in paying enough attention to what the late John Stevenson posted about repairing motor shafts to extend the shaft to fit a Bridgy pulley and keep it all concentric!
    Charles
  17. #14
    Virginia
    28,010
    7561
    8686
    Charles
    Yazz, But B-C would find a "niche" of some sort or other and be "different" in some detail.
    Looks a good solution!
    We DO see ISO / IEC / Euro-Spec.. wotever.. motors even in the US. Used-but-good out of parted-out imports. Not many to our grid specs, but some.
    Just for giggles, minutes ago I dragged a 2 HP 180 VDC Dinosaur Current Reliance RPM III over to where I could get chainfalls onto the loop, get a scale under it.
    150 lbs, Avoir. That'll work on my Quartet - motor sits mid-ram, not on the head & spindle.
    Your AC 3-P motor was what? 35 lbs? Or even less?
  18. #15
    Jul 2009
    UK
    113
    53
    14
    About 30-40lbs. Aluminium framed.
    Charles
  19. #16
    Virginia
    28,010
    7561
    8686
    Charles
    I'd suggest a write-up on it, fotos and such. Or links to such if you have already done that.
    Worth copying.
    Bill
  20. #17
    Oct 2005
    15,994
    Whats so bad about the pancake style of motors ?
  21. #18
    Virginia
    28,010
    7561
    8686
    Mostly that they are in a minority, thus hard to find CHEAP replacements for.
    The BirdPort ones are not even all that "pancaked", and there IS room for other options.
    Replacing the one on a Quartet combo mill as powers the knee? More challenging, by far. Space available thing.
  22. #19
    Jul 2009
    UK
    113
    53
    14
    Worth copying.
    Bill
    Sorry Bill - It was a long time ago (2003/4) before mobile phones took pictures of everything.
    The best I can do is point to a previous thread with John's wisdom. It's really simple if you take apart the motor, have a decent sized lathe and mig/tig. The rest is standard boring/turning/keyway slotting. The slotting may be hard if your only mill is out of action....
    Bridgeport J head 1hp motor replacement -
    The Home Shop Machinist & Machinist's Workshop Magazine's BBS
    Charles
