6F-A power feed questions
Results 1 to 10 of 10
    Sep 2019
    Georgia
    Default 6F-A power feed questions
    I have a 1948 Bridgeport with what I believe is called a 6F-A power feed (learned that from another thread). It works fine and is in good condition internally, but it leaks oil like crazy.
    - Is the gearbox supposed to be full of oil? I don't see how else the top gears could stay lubricated.
    - If so, how should I stop the leaking? There is a place to add oil that is near the bottom of the gear box; should I plug it up somehow? Caulk the rest?
    This is my first mill and I've still got a lot to learn. I appreciate any help.
    Cory
    Attached Thumbnails Attached Thumbnails unnamed3.jpg   unnamed2.jpg   unnamed.jpg
    Dec 2013
    Fort Wayne, IN
    659
    730
    241
    Thats a gear driven power feed. They were obsolete before I started working on them so my knowledge on them is basically zero. All I can help with is the few parts that we have, but not sure about your oil leak.
    Jon
    Sep 2019
    Georgia
    Thanks for your response. I messaged you a minute ago about this before I realized that you had already responded here; sorry about that. You seem to be the guy here who knows the most about these things . . . so I guess I'm on my own with this.
    Cory
    Dec 2013
    Fort Wayne, IN
    659
    730
    241
    Not at all an issue. Most of my experience in the gear driven feeds is taking them apart to get to a part that a customer needs. Sorry I couldnt be of any help.
    Jon
    Sep 2006
    Sacramento County, California
    3,701
    2339
    1262
    I don't know anything about a Bridgeport Power Feed, but I do have a vintage1940 Parks 4 X 12" wood plane. It's got a transmission on the side that drives the feed rollers. It's got some gears and a small chain drive inside. I use heavy fiber grease on it and it's still running after many years.
    I wonder if you could use grease on the gears? That would solve your oil leak.
    Sep 2009
    Phoenix,AZ
    1,755
    2678
    442
    Go to your nearest Tractor supply or the like and get a tube of "picker head grease",this is a flow able grease .It will stay in where oil won't ,about the consistency of honey at 75* of so.
  7. Likes Newman109 liked this post
    Sep 2019
    Georgia
    Never heard of "picker head grease." That's great to know. Appreciate everyone's input!
    Cory
  9. #8
    Jul 2001
    North Carolina
    1,939
    164
    387
    To be technical,
    grease that will flow has a thickness of
    #0 or #00. Most grease is #2 and as you
    know, is way too thick.
    You might consider petroleum jelly (Vasoline)
    as a lube for your gears. It is not grease
    but rather 100% petroleum, and lubricates
    very well in room temperature environments.
    -Doozer
  10. #9
    Jul 2019
    UNITED KINGDOM
    9
    I had one of these on my uk Adcock and shipley 1hp, There are 2 oil cups on the top of the cover which you are meant to oil weekly. Under the high/low knob on the side there is another oil cup which you fill to level,it's not much oil but everytime I looked inside everything was getting well lubed.Where is your feed leaking from?20190913_213035.jpg
  11. #10
    Jul 2019
    UNITED KINGDOM
    9
    Couple of photos from my manual, shows to lube with Vactra oil heavy medium.
