Polaraligned
Hot Rolled
- Jan 28, 2007
- Northern, NJ
I have a Fafnir JM207K PRB DB matched set of ABEC 3 bearings.
Any reason not to use these for my 2J head spindle?
Machine is an occasional user and heating should not be an issue.
Also, what way to install them- thrust faces of outer rings together
or non-thrust faces of outer rings together.
How about preload? Matched sets usually have some built in
preload. How do I know if these bearings have the correct
preload, or does it not really matter.
Scott
Scott
