Hi all,
I reassembled my knee after a painting project. Interestingly, the Z-axis hand crank now makes a grinding noise typical of overly-tight backlash adjustment. The two bevel gears are very obviously too tight.
How is this adjusted? I tried loosening the set screw on the upper bevel gear, but it appears to be slid all the way outwards. Truthfully I don't understand how the entire assembly is constrained; the bearing seems to "float" in the casting. I also tried smacking the entire shaft outwards with a rubber mallet, to no avail. Any other suggestions?
