madmachinst
Stainless
- Jan 15, 2007
- Central FL
Have ASCO JB38A214A press switch. Hooked up my unregulated air, which is probably about 140 PSI, and this seemed to have blown out a little safety valve. Is this thing repairable? Its an aluminum band that holds an O ring and a small plug in there. I was thinking, just ziptie it in there and next time regulate the air going into the machine down to like 90 PSI. I didn't think it needed to be regulated down cause I have a regulator after the sensor ( maybe some one redid the piping?). If it needed regulating then the regulator would just be placed before the sensor and problem solved.
