dfgrice
- Dec 28, 2011
- Stone Mountain, GA
Hi all,
I am getting a lot of noise in back gear. I have a Series 1, head serial number J83430. I have searched through the Bridgeport forum and a lot of good info. However, my dilemma does not quite seem to match, maybe....
I removed the cam ring pins. Found no wear. Cam ring grooves look to be in good shape as well. Reinstalled. Found the upper bearing lock nut loose. Tightened it up. Then tried to shift to back gear. The cam ring required a good bit of force to rotate to back gear. I also could not move the pulleys to shift to back gear. They seemed to be locked up. I shifted back to high speed. It operated fine.
I loosened the upper bearing lock nut about 3/4 to 1 turn. Now back gear operates as it should without any noise such as the clattering that I have been experiencing.
I noticed conversations about putting a shim under the cam ring. But since the upper bearing lock nut seems to change the operation I would rather not waste the time to try the shim.
Any thoughts or suggestions?
Dale Grice
Dale Grice
