I am rebuilding a Hardinge Superslant. I have the servos redone, the IO done, a new PLC and just about everything is/was working before the big final push. I am following in the footsteps of RobH in Brittan who has done the same on several Hardinges
Hardinge Superslant retrofit - LinuxCNC
Below are my thoughts on why/how I think the spindle broke. All I know now is that it is in Fault mode and does not want to come out.
Outside of that thought as to why it isn't working, I am looking at how to see if the spindle drive is broken. I have spent some time translating the servo drive manual, but it appears I cannot upload it here without compressing it to a .txt file as provided. The servo drive is a 6RA2625-6DV54-57. It is a 10kW shunt motor running at 380VDC.
I have checked the mains voltage, field supply, tachogenerator lines, the field loss relay and sensor. I have tried to find what the LEDs mean but have not had success there.
Looking forward, what options or suggestions are out there? I have found minimal information about the Hardinge Superslant spindle online. Does someone have skills that could point me as to where I can find more info on how to get the drive to work or what the drive may have wrong? My current next plan is to read more about the drive, then take out the cards and measure each diode, look for damage, inspect the power circuit, and see if I can find a broken part. I would guess a diode has blown, but that is my guess.
As well, I would be open to getting a new second-hand spindle, however I do not know where to look. 10kW, 5200rpm, 230VAC/380VAC available.
I was powering up the circuits to test the spindle encoder when I found the servo drive, the only part of the old machine I kept around, not getting out of fault. I found this odd as I had the spindle fine months ago. No changing of the wires to the spindle or spindle drive. The field loss relay was clicking on and was fine.
Searching I found 405-408VAC on the input lines to the drive. That was high and odd. Looking at the power to the lathe I found it was outputting 246VAC. The transformer, a 30kA transformer taking 600VAC to 240VAC came with the lathe. The wires were at the middle state when producing 240VAC. I then dropped the down to 235VAC after finding the lathe is to run at 230VAC.
I have been rebuilding this lathe for many months. I have testing many parts and have not had this error from the servo drive before.
As the lathe is not operational, and some projects required 230-240VAC power for testing. Water heaters, motors, stuff that needs a few kva for testing.
It is my thought that the lathe was, when purchased from the old company and when I did earlier testing wired at 235VAC at the 95% step down output. When it was wired back after use on other junk, it was wired back at 100%, or 245VAC output. I didn't notice, nobody noticed.
I remember testing something months ago, turning it on and thinking I was smelling something from the spindle drive. I smelt around it and looked at the cards but could not find anything standing out. I checked the wiring, seeing it was at the 100% on the transformer, but didn't think more than that. I think I smoked something, but I can't be sure.
