Bevel Beveling T-slots after resurfacing table - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21
    Mar 2009
    4,468
    82
    769
    You could use a block of wood with a 45 degree bevel and rest your file on the bevel. The angle wood be consistent but the depth would have to be judged by eye. Long continuous strokes with even pressure. If it was me I would not check my file skills on a table like yours, I would build a jig out of scrap wood and attach a file to it. I would not use metal for the jig to prevent scratching the table.
  2. Likes itsmeBernie liked this post
  3. #22
    Dec 2005
    UTAH
    499
    40
    28
    If you want a uniform bevel, machine it. Someone above has suggested to rotate the head and ram on the column and slide the ram out far enough to reach the slots and machine it. Can't be that difficult.
  4. Likes itsmeBernie liked this post
  5. #23
    Jul 2005
    Northern New Jersey
    511
    2480
    61
    Quote Originally Posted by moldcore View Post
    It’s not on the machine.. I purchased this as a second table.. I got lucky as it is already so much better than the current one.
    Bernie
  6. #24
    Jul 2005
    Cottage Grove, MN 55016
    7,029
    3783
    4179
    I file them too, but wear some leather gloves , those edges get sharp. I'm not a big fan of Blanchard grinding the tables though. Cheaper, but to me that looks bad. Bernie, LTNS..... :-)
    Will take maybe 10 minutes to file it with a rough bastard file and then 5 min with a smooth cut. Rich
  7. Likes itsmeBernie liked this post
  8. #25
    Apr 2006
    Manchester, England
    7,352
    955
    4342
    I agree regarding the " Blanchard " grinding. When I was first starting out a customer sent out the ram off a big ( 21" stroke ) slotter for grinding. I left the job in their hands expecting it to be surface ground. In fact the back two ways of the ram were ground on the British version of a " Blanchard " grinding machine called a " Lumsden " .
    It came back with a 0.003" dip in the middle of the ram ways that I had to scrape out. If your table is parallel you've done very well.
    Regards Tyrone.
  9. Likes Richard King, JRIowa, itsmeBernie liked this post
  10. #26
    Dec 2015
    Connecticut
    253
    22
    71
    Quote Originally Posted by itsmeBernie View Post
    Bernie
    It could be
  11. Likes itsmeBernie liked this post
  12. #27
    Jul 2005
    Northern New Jersey
    511
    2480
    61
    Thanks Folks
    It is taking me ages to get to this. I know the official way, at the factory, was to machine the deep bevels. I see that you are all down with filing, or machining in place. I am sure I will be fine with one of those methods, and I plan to use the machine, so whatever it looks like when I finish it, it will not stay that way forever, either way.
    I may make up that tool holder that Mud suggested and posted the thread. I may also make a little jig to hold files at 45°, so I can get a nice, consistent cut. Otherwise, I am sure I will achieve a nice radius! hah hah
    I will post pics of the final job, and what I did, for the record.
    Thanks Everyone
    Bernard
