Bridgeport Base Hole Size
Likes Likes:  0
Results 1 to 8 of 8
    Sep 2020
    Maryland
    73
    152
    Default Bridgeport Base Hole Size
    The Bridgeport manual I have says that the base holes are 5/8" diameter. My newly purchased Series I, 1 hp mill has 5/8" holes in the front and 9/16" holes in the rear.
    I'm just curious as to whether this is unusual, or if there is a lot of variation in Bridgeport base hole sizes.
    Feb 2021
    New York
    8
    Quote Originally Posted by mrplasma View Post
    I think there is some variation though not sure if it's factory variation or people modifying them after the fact. Mine are tapped at 3/4x10 with leveling jack screws.
    Jul 2005
    Cottage Grove, MN 55016
    8,623
    4520
    5084
    In the old days they used those holes to lag it to the shipping skid. In later machines and other copies started to use them for leveling. I used to tap the holes too, or drilled to a tap size and tapped them about half the time. Many could carless if they are leveled. I use to on mine as I like using a level when setting up parts in the vise. Quicker to get it close before indicating it.
    Jun 2011
    247
    53
    81
    Any chance they are full of bondo? or some paint and filler?
    Sep 2020
    Maryland
    73
    152
    The front two holes run through about an inch and a half of solid cast iron before reaching the cavity below. The two rear holes have about a half inch of cast iron before opening up. No bondo or other filler.
    I'm going to locate two lengths of 5" x 2" x 1/4" wall rectangular tubing across under the front holes and rear holes. I plan to use retractable adjustable casters in each corner.
    Dec 2013
    Fort Wayne, IN
    866
    882
    308
    Quote Originally Posted by Richard King View Post
    We make leveling feet bars and go through them like hot cakes. I know there are a few different bases for Series 1's (Man, JR would have jumped all over me for that one) but to my knowledge, the spacing and hole sizes were all the same. I will get to the graveyard later and check them out.
    Jon
    Feb 2021
    New York
    8
    Quote Originally Posted by HWElecRepair View Post
    I've seen that setup you have, looks quite good. I'm curious if you've ever considered using something like the Footmaster casters with it? I keep toying with a setup like that, or just a pallet jack for occasional mobility.
    ETA: After I posted this, I realized the appropriate sized Footmaster casters would raise the mill up a good 6" or so, which wouldn't be great for a number of reasons. Would need one of the more complicated bracketed examples I've seen for this to work.
    Dec 2013
    Fort Wayne, IN
    866
    882
    308
    Quote Originally Posted by mchasal View Post
    Not really. I have seen a bunch in garages and barns that make them easier to move around because of the limited space in a smaller shop.
    Jon
